Command line restart of access point wap4410n
haneef0011
Hi ,
Does anybody know if there is an option to restart cisco wap4410n via command line. I couldn't see  a command to do this.
Tiago Marques
you have ssh connection to the wap4410n?
test :
rc wlan stop
rc wlan start
on internet only find this procedure:
Reboot with the use of the Web-based utility
Step 1. Log in to the web configuration utility page and choose Administration > Reboot. The Reboot page opens:
Step 2. To reboot the device, click the radio button Yes to reboot the access point from its web-based interface.
Step 3. Click Save to save the set up. Rebooting the device will not cause the device to lose any of the stored configuration.
Hardware Reboot
Step 1. Press the Reset button for less than  eight seconds with a pin located at the back of the device.
Step 2. The Access Point reboots and is refreshed.
nettam.naveen
Try this commands,
rc wlan stop
ifconfig br0 down
ifconfig br0 hw ether xx:xx:xx:xx:xx:xx
ifconfig br0 up
rc wlan start
Thanks.
slstratt
Hello haneef0011,
Thank you for using the Small Business Support Community!
Unfortunately, the command line interface (CLI) is not a valid configuration method for the WAP4410N and is not supported.
If you have any other questions, please feel free to post them here and I will do my best to help!
Best,
Taylor
nettam.naveen
Thank you for the update Taylor..
Naveen
