Device connected via LAN to WAP4410N zo access WLAN/LAN
fritz.kalkreuth
I have my LAN/WAN on one floor and WLAN Devices on two additional floors which cannot be connected physically (via Ethernet cable) to the LAN.
The WAP4410N is connected via Ethernet cable to a device (2nd Floor) and should connect to the WLAN of my Fritz Box (1st Floor)
There are two additional WLAN Routers on the 3rd Floor which should also be members in this WLAN using a single SSID.
Remember: WLAN devices on the 2nd and 3rd Floor cannot be connected to my LAN (via Ethernet cable) directly.
How do I have to configure These devices?
Any help would be very appreciated
ktonev
Hello Fritz,
My name is Kristian and I am one of the engineers from the Small Business team.
Since you cannot use an Ethernet cable to connect the WAPs to your LAN, please look into the Wireless WDS Repeater/Bridge functionality supported by the WAP4410N device. These features should allow you to configure your network the way you want to.
You can refer to the administration guide for this device here for more information.
Hope that helps!
Kris
