WAP 351 total associated clients and MIBS
comparea
Hi all,
I've just installed a Cisco WAP351 AP and I would like to monitor the total clients associated with SNMP software, but, I'm wondering the total amount of possible informations that I can reach trough MIBS and then I can't find the right OID to monitor what I need: "Associated Clients" (the same info that I can see in GUI at "Status and Statistics" tab.
Can someone indicate the right field of which MIBS I need to use?
Thanks.
Gisueppe Albanese
Ingrid Aragon
Gisueppe, I am a Cisco Engineer from the Small Business department.
The Wireless Access Point MIB-1.0.1.4 is available in our Cisco Website. However, I am checking with the level 2 if there is any OID/MIB to monitor the associated clients to the WAP351. I will keep you posted.
Why should I rate content?
You'll be ensuring that people who generously share their expertise are properly acknowledged. As posts are rated, the value of those ratings are accumulated as "points" and summarized on the Member Profile page and on each member's Preferences page.
Thank you.
Giuseppe
Is there any update?
Giuseppe
