Error AP POWER
lisavbedt
Level 3
Level 3
l getting error on ap is flashing red green and blue and my switch is cisco small business SF300-POE And no wifi this ap is covert to me newest version sill flashing red green blue
https://www.cisco.com/c/en/us/products/collateral/wireless/aironet-2800-series-access-points/datasheet-c78-736497.html#Productspecifications
Input power requirements
●  802.3at PoE+, Cisco Universal PoE (Cisco UPOE ®)
●  802.3at power injector (AIR-PWRINJ6=)
Whether or not your SF300 switch supports 802.3at depends on the exact model number of the switch. Refer to the Power over Ethernet (PoE) table at https://www.cisco.com/c/en/us/products/collateral/switches/small-business-smart-switches/data_sheet_c78-610061.html to see whether your switch supports it or not.  If not then you will need a power injector or switch which does support 802.3at (POE+).
Please click Helpful if this post helped you and Accept as Solution if this answered your query.
TAC recommended codes for AireOS WLC's   and   TAC recommended codes for 9800 WLC's
Best Practices for AireOS WLC's,   Best Practices for 9800 WLC's   and   Cisco Wireless compatibility matrix
Check your 9800 WLC config with Wireless Config Analyzer using "show tech wireless" output or "config paging disable" then "show run-config" output on AireOS and use Wireless Debug Analyzer to analyze your WLC client debugs
Field Notice: FN63942 APs and WLCs Fail to Create CAPWAP Connections Due to Certificate Expiration
Field Notice: FN72424 Later Versions of WiFi 6 APs Fail to Join WLC - Software Upgrade Required
Field Notice: FN72524 IOS APs stuck in downloading state after 4 Dec 2022 due to Certificate Expired
- Fixed in 8.10.196.0, latest 9800 releases, 8.5.182.12 (8.5.182.13 for 3504) and 8.5.182.109 (IRCM, 8.5.182.111 for 3504)
Field Notice: FN70479 AP Fails to Join or Joins with 1 Radio due to Country Mismatch, RMA needed
Field Notice: FN74383 APs Running 17.12.4/5/6/6a May Run Out of Flash Space Preventing Upgrades
How to avoid boot loop due to corrupted image on Wave 2 and Catalyst 11ax Access Points (CSCvx32806)
Field Notice: FN74035 - Wave2 APs DFS May Not Detect Radar After Channel Availability Check Time
Leo's list of bugs affecting 2800/3800/4800/1560 APs
Default AP console baud rate from 17.12.x is 115200 - introduced by CSCwe88390
12 Replies 12
Mark Elsen
     - That means that the AP is getting insufficient power ,
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
How do l fix it ? Do l need switch with poe+??
 - Start by looking at the datasheet of the particular AP model and look for powering requirements, then compare to switch capabilities , or find other switch model (e.g.) ; or use power adapter
 M.
       Beauty and terror
      Just keep going
       No feeling is final
Rich R
What model of AP?
What version of software?
Do you have CDP or LLDP enabled on the switch port?
  • no l think not and ap is update to newest version ME
  • no l think not
    CDP or LLDP is required for POE+ to work correctly.
  • and ap is update to newest version ME
    So you confirm it is running 8.10.190.0?
Good Reading l orderd new switch Cisco with poe+ when arrived l hope its works?
Yes ap running newest version
Al model is airap2802i-b-k9
problem is sloved its was switch new switch is arrived with poe+ and worked normal en showing my wifi thanks everyone
Glad to hear you worked it out.
