Help needed setting up access point to public network
glenn.pearce
Hi from a newbie,
Assuming they are suitable, I want to use one (or two) AP1232AG-E-K9 access points for Internet connection through a public wireless network (BTFON), where wire broadband is not an option. I've downloaded what I think is the correct manual for the APs and I'm now scratching my head as to where and how to start setting them up. I want to use these Cisco APs in the hope they will give me better wireless performance than I'm currently getting, which is frequently flakey.
I've tried to reset the APs to the factory default but there seem to be different ways of doing this depending on what you want and what you've got. I made up a console cable  to access the console but there even appear to be different versions of  this so I'm not sure if the cable I have is the correct one.
I have setup and used lower end wireless devices in the past but these Cisco units seem real complicated and I'm going to need help in getting them working.
Any assistance would be much appreciated.
Kind regards,
Glenn.
39 Replies 39
glenn.pearce
If this posting is in the wrong place please relocate it and let me know where is has been moved to.
kcnajaf
Level 7
Level 7
Hi Geln,
Please let us know how exactly you are planning to connect this AP to provide internet? Are you planning to bridge the wireless connection from BTFON? Have you mange to get console access to the device now?
Najaf
I hoped I could connect the AP directly to a laptop or desktop via the Rj45 wired network ports as per the drawing below, however, I'm open to suggestions.
As I said before I'm not sure the manual(s) I downloaded or the console cable i've made up are the correct ones. The manuals I found are:
  • Cisco Aironet 1200 Series Access Point Hardware Installation Guide, OL-2155-02.Text Part Number: OL-7043-02
  • Cisco Aironet 1200 Series Access Point Hardware Installation Guide. December 2006. Text Part Number: OL-8370-04
I also found reference to AP1230 series devices but which is the correct one I don't know. Perhaps you could advise or point me in the direction of the correct manual.
I'm wary of using the console cable I made up because it differs from other pinout arrangements I've found as shown below. Once again perhaps you could advise or point me in the direction of the correct pinout.
The pinout for the console cable I made up is the same as that shown in the 1200 series manuals and is as follows:
Rj459Pin (subD)
Pin   3 (TXD)2   (RXD)
Pin   4 (GND)5   (GND)
Pin   5 (GND)5   (GND)
Pin   6 (RXD)3  (TXD)
Other pinouts found use the same basic 4 connections as above but also have additional pins connected and are:
RJ45 DB9
RTS18CTS
DTR26DSR
TXD32RXD
GND45GND
GND55GND
RXD63TXD
DSR74DTR
CTS87RTS
and
DB-9RJ-45 Dir
Receive Data23<--
Transmit Data36-->
Data Terminal Ready47-->
Ground (use as shield)55---
Ground (use as shield)54---
Data Set Ready62<--
Request to Send78-->
Clear to Send81<--
I've edited this post to remove some errors.
Hi Glenn,
As far as my understanding goes you could get your above requirment fulfilled if you configure your Cisco AP as a work group bridge.
Please flow below link for the configuration guide.
http://www.cisco.com/en/US/products/hw/wireless/ps430/products_configuration_example09186a00805b9b87.shtml
Also please find the pin out diagram which would be used by Cisco devices for console connectivity. My understanding all console cables have the same standard.
Use this cable to configure a Cisco router through the Console port at the router.
9 PIN D-SUB FEMALE
9 PIN D-SUB FEMALE to the Computer
RJ45 MALE CONNECTOR
RJ45 MALE CONNECTOR to the Cisco router
RJ45DB9
RTS18CTS
DTR26DSR
TXD32RXD
GND45GND
GND55GND
RXD63TXD
DSR74DTR
CTS87RTS
Najaf
I've modified my console cable to give the same pinout as in the table above. As far as I'm aware I can now access the console.
At the moment the AP is connected via the console cable and has a hard wired connection to a Wireless Broadband Router (which has it's wireless disabled) and I can access the APs GUI. Here is the System Software page info:
Product/Model                                       Number:AIR-AP1232AG-E-K9
Top                             Assembly Serial Number:FCZ1033Z24A
System                                Software Filename:c1200-k9w7-tar.123-8.JA2
System                                    Software Version:12.3(8)JA2
Bootloader                                             Version:12.3(2)JA4
Where do I go from here?  Presumably I need to reset the AP to its factory defaults? so that I can start afresh?
Cheers.
Hi Glenn,
Good to know that you now have console access to the device. You could reset the device with "write erase" command from console and issue "reload" which will then re-boot with default configuration.
Najaf
How do I do these 2 things?
I've started HyperTerminal then switched on the AP and watched it boot in the terminal window, pressed enter and the terminal window command prompt now sits at 'ap>'
Glenn
Hi Glenn,
From ap>enable
Password:Cisco
AP# Write Erase
AP# Reload
Najaf
Thanks Najaf.
OK done that. However, the rebot log shows some errors, are they a problem. If not, where do I go from here?
Below is the boot log.
Thanks again,
Glenn.
ap>enable
Password:
ap#Write Erase
Erasing the nvram filesystem will remove all configuration files! Continue? [con
firm]
[OK]
Erase of nvram: complete
ap#
*Mar  1 02:32:32.002: %SYS-7-NV_BLOCK_INIT: Initialized the geometry of nvram#
ap#Reload
Proceed with reload? [confirm]
*Mar  1 02:32:53.354: %SYS-5-RELOAD: Reload requested by console. Reload Reason:
Reload command.Xmodem file system is available.
flashfs[0]: 148 files, 7 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 7741440
flashfs[0]: Bytes used: 4948480
flashfs[0]: Bytes available: 2792960
flashfs[0]: flashfs fsck took 13 seconds.
Reading cookie from flash parameter block...done.
Base ethernet MAC Address: 00:18:b9:0f:ed:d8
Initializing ethernet port 0...
Reset ethernet port 0...
Reset done!
ethernet link up, 100 mbps, full-duplex
Ethernet port 0 initialized: link is up
Loading "flash:/c1200-k9w7-mx.123-8.JA2/c1200-k9w7-mx.123-8.JA2"...#############
File "flash:/c1200-k9w7-mx.123-8.JA2/c1200-k9w7-mx.123-8.JA2" uncompressed and i
nstalled, entry point: 0x3000
executing...
              Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
           cisco Systems, Inc.
           170 West Tasman Drive
           San Jose, California 95134-1706
Cisco IOS Software, C1200 Software (C1200-K9W7-M), Version 12.3(8)JA2, RELEASE S
OFTWARE (fc1)
Copyright (c) 1986-2006 by Cisco Systems, Inc.
Compiled Tue 30-May-06 18:07 by pwade
Image text-base: 0x00003000, data-base: 0x00692480
Initializing flashfs...
flashfs[1]: 148 files, 7 directories
flashfs[1]: 0 orphaned files, 0 orphaned directories
flashfs[1]: Total bytes: 7741440
flashfs[1]: Bytes used: 4948480
flashfs[1]: Bytes available: 2792960
flashfs[1]: flashfs fsck took 2 seconds.
flashfs[1]: Initialization complete....done Initializing flashfs.
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco AIR-AP1232AG-E-K9    (PowerPC405GP) processor (revision A0) with 15038K/13
36K bytes of memory.
Processor board ID FOC103125KJ
PowerPC405GP CPU at 196Mhz, revision number 0x0145
Last reset from reload
1 FastEthernet interface
1 802.11 Radio(s)
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 00:18:B9:0F:ED:D8
Part Number                          : 73-8704-12
PCA Assembly Number                  : 800-23211-13
PCA Revision Number                  : A0
PCB Serial Number                    : FOC103125KJ
Top Assembly Part Number             : 800-23304-13
Top Assembly Serial Number           : FCZ1033Z24A
Top Revision Number                  : B0
Product/Model Number                 : AIR-AP1232AG-E-K9
%Error opening tftp://255.255.255.255/network-confg (Socket error)
%Error opening tftp://255.255.255.255/cisconet.cfg (Socket error)
Press RETURN to get started!
*Mar  1 00:00:04.077: %SOAP_FIPS-2-SELF_TEST_IOS_SUCCESS: IOS crypto FIPS self t
est passed
*Mar  1 00:00:05.214: %SOAP_FIPS-2-SELF_TEST_RAD_SUCCESS: RADIO crypto FIPS self
test passed on interface Dot11Radio 0
*Mar  1 00:00:07.307: %SYS-6-LOGGERSTART: Logger process started
*Mar  1 00:00:07.309: %LINK-3-UPDOWN: Interface FastEthernet0, changed state to
up
*Mar  1 00:00:08.309: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthern
et0, changed state to down
*Mar  1 00:00:16.228: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthern
et0, changed state to up
*Mar  1 00:00:21.399: %SYS-4-CONFIG_RESOLVE_FAILURE: System config parse from (t
ftp://255.255.255.255/network-confg) failed
*Mar  1 00:00:21.484: %SYS-4-CONFIG_RESOLVE_FAILURE: System config parse from (t
ftp://255.255.255.255/cisconet.cfg) failed
*Mar  1 00:00:26.394: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to a
dministratively down
*Mar  1 00:00:26.478: %SYS-5-RESTART: System restarted --
OFTWARE (fc1)
*Mar  1 00:00:26.478: %SNMP-5-COLDSTART: SNMP agent on host ap is undergoing a c
old start
*Mar  1 00:00:27.394: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio
*Mar  1 00:00:27.427: %LINEPROTO-5-UPDOWN: Line protocol on Interface BVI1, chan
ged state to up
*Mar  1 00:00:36.936: %DHCP-6-ADDRESS_ASSIGN: Interface BVI1 assigned DHCP addre
ss 192.168.1.72, mask 255.255.255.0, hostname ap
ap>
That looks fine. Please provide below out put.
ap>enable
Password:Cisco
ap# sh ip int brief
ap# sh run
Najaf
Najaf results as requested,
ap>enable
Password:
ap#sh ip int brief
Interface                  IP-Address      OK? Method Status                Prot
ocol
BVI1                       192.168.1.72    YES DHCP   up                    up
Dot11Radio0                unassigned      YES unset  administratively down down
FastEthernet0              unassigned      YES other  up                    up
ap#sh run
Building configuration...
Current configuration : 1141 bytes
version 12.3
no service pad
service password-encryption
hostname ap
enable secret 5 $1$vvzL$U4MLOAVd7z26FL5l4U0Zc0
ip subnet-zero
no aaa new-model
username Cisco password 7 112A1016141D
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
shutdown
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0
54.0
station-role root
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface FastEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
bridge-group 1
hold-queue 160 in
interface BVI1
ip address dhcp client-id FastEthernet0
no ip route-cache
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
control-plane
bridge 1 route ip
line con 0
line vty 0 4
login local
end
What is your public wireless network SSID? Does this use any sort of authetication?
Najaf
The BTFON public wireless network SSID can change depending on which Hotspot your looking at . It appears there are several Hotspots with the same SSID all of which you can pick up if your AP is in range. In the area I want to use the AP there are at least 4 different BTFON Hotspots with different SSIDs including:
BT Openzone
BT WiFi
BT Fon
BT WiFi with Fon.
plus serveral with the same SSID.
BT WIFI and BT WIFI with FON superceed the other two which I guess will be phased out at sometime.
There does not seem to be any authentication required except ones own login details which should work for all of the BTFON hotspots all over the country.
Glenn.
Ok Fine.
Try applying below configuration
conf terminal
ssid XXXXX (pick one of the SSID which have good signal and replace with XXXXX)
station-role workgroup-bridge
no shut
dot11 ssid XXXXX
authentication open
exit
After applying this please provide output of below command. Ensure that cable is removed from Fastethernet0 interface
ap#sh ip int brief
ap#sh dot11 ass
Najaf
