Help WAP4410N configuration with 6 repeater
egegegeg1
Hi, need help configuration WAP4410n.
I configure 1 wap4410n mode access point, is ok
I place 6 wap4410n in building as wireless repeater.
I can not configure the right sequence.
How do I set up 6 repeaters with access point ?
Tom Watts
Hi EG, this is unsupported. You may repeat only 3 ap.
-Tom
Please rate helpful posts
-Tom Please mark answered for helpful posts http://blogs.cisco.com/smallbusiness/
Thanks for answer.
I tried to configure one access point and one repeater :
1 mode configuration
Access point mode and select "Allow Wireless Signal to be repeated by a repeater"
insert mac address second accesspoint
2 mode configuration
Wireless Client/Repeater select "Allow wireless stations to associate"
site survery, select accesspoint 1
Remote access point insert mac address site survey
I used two access point the same SSID,channel,wpa2 personal
First access point, positioned on the ground floor
Repeater, positioned first floor
My computer wifi takes the signal from access point only as far, why ????
On the first floor if I move computer wifi takes no signal repeater.
Why? Where am I wrong?
Did you get your answer, or the problem figured out?
