How to configure Authentication-Type = PEAP on Cisco Rv 120W
chicagotech
I am configuring Cisco RV 120W Wireless and want to setup WPA2 Enterprise with PEAP. However, I can't figure out where to setup PEAP. Can someone elp?
jeffrrod
Level 4
Level 4
Dear Customer,
Thank you for reaching the Small Business Support Community.
The RV120W supports Port-based RADIUS authentication (Extensible Authentication Protocol [EAP], Protected EAP [PEAP]).  Please refer to page 109, chapter 5, for RADIUS configuration settings guidelines (those are the only RADIUS available configurable settings);
http://www.cisco.com/en/US/docs/routers/csbr/rv120w/administration/guide/rv120w_admin.pdf
Please check on the below threat where someone inquired about some known issue;
https://supportforums.cisco.com/message/3697817#3697817
If you require further assistance I suggest you to contact support directly;
https://supportforums.cisco.com/community/netpro/small-business/sbcountrysupport
Please do not hesitate to reach me back if there is any further assistance I may help you with in the meantime.
Kind regards,
Jeffrey Rodriguez S. .:|:.:|:.
Cisco Customer Support Engineer
*Please rate the Post so other will know when an answer has been found.
Jeffrey Rodriguez S. .:|:.:|:. Cisco Customer Support Engineer *Please rate the Post so other will know when an answer has been found.
