Wireless - Small Business
Stay connected on-the-go with our Wireless solutions, designed for small businesses to boost productivity.
Don't miss this Cisco Catalyst 8000 offer
Labels
Update - We have completed the relabeling project for the wireless board. We will be lifting read-only mode today the Sixth of May. Thank you all for your patience and feedback.   We are approaching our latest step in relabelling posts across the Sma...
CoreyP319 by Cisco Employee
  • 642 Views
  • 0 replies
  • 1 Helpful votes
Hello!   This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.    Virtual Assistant- Discover support content and options for your gearSupport page index - Contains a ...
  • 2864 Views
  • 1 replies
  • 5 Helpful votes
HelloI have a WAP321. The unit hangs about on every day. Web interface and WLAN let not respond anymore. By a reset the unit will be back. I have put all unnecessary stale. Tracing the turned on, I can say nothing flashy.Martin
The issue I am having is when I use the Wizard to setup the unit and change the password. It then tells me the password/username is invaild. I have rset the unit and have tried a few times. If I don't use the wizard it works fine.Any ideas?
drobinson by Level 1
  • 2370 Views
  • 3 replies
Hello all,At home (pretty big house) we now have 2x WAP321 access points installed which work perfectly, however from a friend I got 2x Aironet 1142 with dual band. In the past i had problems though with aironet not keeping the wifi connection in tac...
Hallo,I have a problem with four WAP321 at various locations.All APs are configured with two WLANs and two VLANs.The APs are connected via the Cisco power supply.After about 7 days, the AP stops responding and you have to separate from the power supp...
fawiersch by Level 1
  • 1555 Views
  • 1 replies
