import certificate on WAP121
davidCPAS
I'm trying to import an SSL certificate (pem file) to allow HTTPS inspection on my WAP121.
When I try to upload using http upload I get the message "The certificate file failed to be uploaded".
I could successfully upload that certificate on a MR33 so I know the certificate is good.
Any idea?
Kind Regards,
David
Rich R
It might require the full cert chain in the PEM file like the WLCs do - try following the "Option B: Obtain the Final.pem File from a Third-Party CA" section of https://www.cisco.com/c/en/us/support/docs/wireless/4400-series-wireless-lan-controllers/109597-csr-chained-certificates-wlc-00.html which should be similar to https://knowledge.digicert.com/quovadis/ssl-certificates/ssl-installation/how-do-i-install-a-certificate-onto-cisco-wlan-controller-wlc.html to create the full cert chain in your PEM file.
