Wireless - Small Business
Stay connected on-the-go with our Wireless solutions, designed for small businesses to boost productivity.
Don't miss this Cisco Catalyst 8000 offer
Labels
Update - We have completed the relabeling project for the wireless board. We will be lifting read-only mode today the Sixth of May. Thank you all for your patience and feedback.   We are approaching our latest step in relabelling posts across the Sma...
CoreyP319 by Cisco Employee
  • 587 Views
  • 0 replies
  • 1 Helpful votes
Hello!   This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.    Virtual Assistant- Discover support content and options for your gearSupport page index - Contains a ...
  • 2835 Views
  • 1 replies
  • 5 Helpful votes
Having a problem roaming from 140AC to 141 mesh extender in a Mesh network.  It drops connection but then has problem reconnection to the next AP.    Running Windows 10 on HP Zbook.  Per the 140 Network administer web GUI.  All AP are up and SNR are ...
sbtechy1 by Level 1
  • 777 Views
  • 0 replies
Good afternoon!I recently replaced a 3com Access Point with the Cisco WAP321 in one of our offices.  Things were working pretty well for a while and then everything hit the fan!  Clients are randomly being disconnected from the AP (I notice this most...
I recently purchased a RV160W and when trying to connect the router will not accept my PPPoE password because it contains special characters (%) is their a fix for this?
QMI by Level 1
  • 798 Views
  • 1 replies
i have 3 units of wap571, since last update:Release 1.1.0.3 WAP571_WAP571E_1.1.0.3.tar 26-Apr-2019the wifi throughput is 20mbps on both 2.4-5ghzi made restore to factory defaults, no vlans , just all units configured as dhcp cliants and wpa2 password...
HAVA by Level 1
  • 1609 Views
  • 3 replies
morning.  first time setting up cisco ap.  company switched providers.   i setup the 1st AP, no problem with all new credentials etc.  It was all configured, online and working.  I setup the second ap, gave it its name and IP.  Once the list refreshe...
CAWINC by Level 1
  • 1689 Views
  • 4 replies
Hi: I have CBW240AC access points. Under Advanced RF Parameters in the controller software, I don't understand the difference between adjusting the 5.0 Ghz (for example) Threshold drop down vs. adjusting the 5.0 GHz Data Rates via the slider bar.I'm ...
mj32 by Level 1
  • 505 Views
  • 1 replies
