% Invalid input detected at '^' marker.
F5MZE
Hi there,
Trying to access to the config terminal, I get error
Here is my process :
Login to my access point via ssh
login as :admin
Using keyboard-interactive authentication.
Password:xxxxxxxxxxx
AP>enable
Password:xxxxxxxxxx
AP#configure terminal
AP#
Any idea ? Thanks for helping
20 Replies 20
config t does not work
F5MZE
Finally find the solution, I have re-created the admin user of the AP from the WLC :
config ap mgmtuser add username <myUser> password <myPassword> enablesecret <myEnablePassword> <myApName>
and now, when I connect to my AP, I can run config terminal
Thanks to all for your help
Please, could you explain how do I reset my admin and password? I have the same problem as yours and I can't do these resets. thanks
I can not do this:
Hi.
i have the same issue, did you figure it out? tried many things but still no luck
I have a little bit different situation please help me i was trying to set the basic switch configuration but when i try to set minimum length of password this error shows up
Switch(config)# no ip domain-lookup
Switch(config)#security passwords min-length 8
