Iphones, Ipads face problem while shifting between diffrent WLAN on WLC 2504
Zohaib Khan
Dear All,
I just create second SSID for different WLAN on my WLC 2504, all client other then Apple devices are successfully able to connect  to new SSID a dnd can swap between two SSIDs but apple device unable to shift to new SSID, if any apple device is not connected to to any of SSID (Fresh connection) then that device is able to connect either of SSID but then unable to swap to other SSID. I enable Fast Transition on WLC as well but no improvement. can any one help me to sort out this issue
WLAN 10.10.10.0/24  SSID1
WLAN 10.10.20.0/24  SSID2
Thanks & Regards
Zohaib
Zohaib Khan
Issue resolved :) by configuring fast SSID changing
got help on following link
https://supportforums.cisco.com/discussion/11527996/difficulty-apple-ios-devices
