Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful. Virtual Assistant- Discover support content and options for your gearSupport page index - Contains a ...
How to I automate a reboot on a Cisco AP541N AP Router?
As the title says - I have a wap4410n acting as AP and a second wap4410n acting as wds repeater.I've only managed to get the wds repeater to work when it has a different ssid to that of the ap - I'd like the wds repeater to have the same ssid as the ...
I need to extend my wireless coverage to another building. What access points, in repeater mode, will the rv220w support? I need an AP with detachable antennas. I have an external mounted antenna on the metal building that I need to hook the AP to...
I have a SonicWALL running DHCP and two WAP321 Access Points. Mac and iOS clients will connect for around 5 seconds and then lose their IP address and use a self-assigned one. The wireless channels are set statically to the least used in our area. Th...
Hey there, looking for some advice.I currently have two (2) Cisco RV180W devices and im looking at expanding my wireless saturation within my house and looking for the best way. a bit of back story... I originally had a signal (1) RV180W and it was l...
Does the WAP 321-E-K9 (as 5GHZ frequency) supports the 802.11a?If yes, please specify exactly the output power transmission in dBm?Is it possible to have the 5GHZ frequency that not support the 802.11a? Because in the technical sheet of the WAP 321-E...
Hi Guyz, I am using WLC 2504 (Sysinfo given below), I created a new SSID on different VLAN, but when i used to connect to it while using previous SSID. Moving between two SSID is very slow. I have to disconnect my wifi then wait for 5 mint and then a...
Hi, I've searched these forums (it seems) exhaustively and found no answer to my particular issue. The following configuration was functioning beautifully until I, in my infinite wisdom, decided to update the firmware on my RVS4000 and WAP4410n. My...
We have an AP541N that has been deployed to replace a Cisco 1200 AP (B/G radio). The 1200 functioned perfectly in our environment. The new AP541N on the other hand seems to work fine right after a reboot but immediately starts to degrade service. ...
I have a RV110W setup as a wireless router right now. There is only 1 wireless network, the private office network. I would like to setup a guest network on its own VLan for internet only access. How do I go about this? Here is my current setup.Vlan ...
Dear All,I just create second SSID for different WLAN on my WLC 2504, all client other then Apple devices are successfully able to connect to new SSID a dnd can swap between two SSIDs but apple device unable to shift to new SSID, if any apple device...
Hey. I am currently setting up a WIFI-Network for a restaurant using the WAP4410n as Access Point with two SSIDs. One SSID is for Guests and the other one is secured and for staff.This second SSID should be repeated to properly supply the offices. Bu...
I have 3 Cisco WAP 2000 and have two SSID's set up with passwords. I usually change the passwords every 3 months or so, but now when I log in I can't even see where I can change the passwords. there is no longer a drop down list under Wireless. There...
Setup my WAP321 this morning. Unplugged network cable. Walked across the street, plugged in for deployment, dead. Tried POE from switch, from injector and even plugged power cord in, nada. How do I get it serviced? We just bought it 1.5 months a...
I am hoping that someone could assist me with my issue. I have been trying to get my WAP4410N setup. I had to do a hard reset on the device. I tried to connect to it via WIFI and the device asked for 8 digit WPS pin. Of course this is unavailable as ...
