Wireless - Small Business
Stay connected on-the-go with our Wireless solutions, designed for small businesses to boost productivity.
Don't miss this Cisco Catalyst 8000 offer
Labels
Update - We have completed the relabeling project for the wireless board. We will be lifting read-only mode today the Sixth of May. Thank you all for your patience and feedback.   We are approaching our latest step in relabelling posts across the Sma...
CoreyP319 by Cisco Employee
  • 679 Views
  • 0 replies
  • 1 Helpful votes
Hello!   This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.    Virtual Assistant- Discover support content and options for your gearSupport page index - Contains a ...
  • 2876 Views
  • 1 replies
  • 5 Helpful votes
Hi, there is a captive portal into this model that seems perfect to give guess access. I live in France, and when you give internet guess access to someone you have to log (for one year!) : -1- name (can be achieve by the person that gives a user), n...
impi by Level 1
  • 893 Views
  • 4 replies
I just received my Cisco VPN Router model RV042. Im just trying to figure out how to set up my wireless equiptment with it, and my main question at this time is:1) How can I get my wireless equipment to connect to the RV042?-Current equipment is Air-...
bmb519881 by Level 1
  • 760 Views
  • 2 replies
I have a similar issue as others have had with the WAP371 and clients disconnecting randomly. most of the discussion didn't have any real content, just said to open a case, which I have not done yet as im still researching this but I wanted to see if...
anthonya1 by Level 1
  • 2446 Views
  • 11 replies
I am attempting to correct the time on my Aironet 1240 AP.  However, when I attempt to update the setting and "apply" them, I am directed to an invalid "page", and the accesspoint will not update and accept the setting. There is currently an invalid ...
ken by Level 1
  • 569 Views
  • 1 replies
Good afternoon.I have some issues wiith WAP321. It works good, but suddenly, after a few days of working, WAP321 looses the packets.Pings from host, connected by WIFI through WAP321 to internet hosts may be like this:64 bytes from 173.194.113.223: ic...
Not sure where to post this or which section sorry if I have it in the wrong section.here is my issue, I have a client that I have set up a Cisco WAP 321 for them to use. here is the deal I have issues with this thing actually working, I had it up an...
I have a V01 (first model WAP) THE WAP4410N V01 WAP IS FAULTY.I hope this helps owners that own this first version ....》》》》》》》》》》》》》》》》》》》》》》》》》》》》Information from firmware update file .... Changes Since WAP4410N Hardware Version VID: V01WAP4410N now...
robweb5mm by Level 1
  • 2095 Views
  • 11 replies
Hi all , I have a query regarding the clustering feature in Cisco 300 series access points .Is it possible to cluster different models of 300 series ( for instance , 3 nos of 321 and 3 nos of 351 ) together ?Tried looking in Datasheets and Literature...
Hi,I tested the last firmware 2.0.7.4 on 10 AP. It was catastrophic because all access points stopped working (no SSID WIFI visible but Ethernet Interface OK) . I downgraded all AP to 2.0.6.1 to solve this problem.Finally, i can't use the last firmwa...
m.zafrany by Level 1
  • 22729 Views
  • 51 replies
I have a WRV-200 wireless router which I never upgraded the firmware. My computer OS is Windows 7 Professional. I just downloaded the upgrade onto my computer, could you please explain to me the next step I need to take to complete the upgrade.Is it ...
