Q. How many 521 AP (standalone mode) can be supported on the Cisco Configuration Assistant? Some documentation says 3 on other says 10. Just want to provide a correct solution for the client.
A: It used to be 3 standlone APs with CCA, and 6 with one controller or 12 with two controllers. But with CCA 1.8, the number of standalone APs increased to 10. There is also an increase in the number of APs supported with a single controller. We'll check with Maryanna Gundall - the moderator of this forum - to see if the controller software has been released yet.
