P2P communication blocked - WLC526
dns-dan
Peer-to-peer communications are being blocked via wireless using WLC526 and LAP521's on same SSID. How do I enable P2P communications?
htarra
Level 4
Level 4
Depending on the P2P applications, you can configure extended access-lists and block the P2P communication.
refer to the following document of cisco. you can do the same sort of blocking on the routers to prevent p2p applications..
http://www.cisco.com/en/US/tech/tk583/tk372/technologies_tech_note09186a00801e419a.shtml#edonkey
Basically I want to disable the blocking entirely. How do I do that with the WLC526? By the way, I tried thelink you provided, but it didn't work.
