Hello!
This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.
Virtual Assistant- Discover support content and options for your gearSupport page index - Contains a ...
I can not get the camera to connect to a 1240AG access point using encryption. It will connect if no encryption is enabled. Has anyone run into this issue before?
Suppose I have 5 access points placed at a distance of roughly 40 meters......each......and i want to roam without disconnection.....and i keep the ssid same for all A.P of Linksys (lets say any Linksys A.P having wireless N).question01.is romaing po...
Helloi have question from end user which need connect two AIR-AP1242AG-E-K9 into bridge mode and using IPX protocolis there support for IPX?regardsTomas
Linksys WET54G connected to HP 420 AP change key types. it works for a day or so and suddenly it change the key-type from WPA-TKIP to WEP. communication fails of course. Restart the units will make it to work again sometimes you will have to restart ...
I am trying to install a AP521 with a WLC526. The AP is in lightweight mode. I have configured the SSIDs on the WLC, and the AP is registering with the WLC, but it says that the dot11radio on the AP is "operationally down". I can't find where to enab...
Hi, I am in the process of configuring my first lightweight AP521. Does the ap itself have an IP address? I figured it would, but I am having a hard time finding / configuring it. CCA has very little configuration options for it.I am thinking, that's...
I ordered a WLC526 for a customer. Howevever, it didn't come with brackets to mount it into a standard 19" rack.I called our distributer support. They said that it's intended to be a desktop unit. However, it has screw holes on the side of it.Does an...
i have the most updated firmware for the device listed in the subject. so onto the question:i created a virtual SSID for my ACCESS POINT and it isn't broadcasting. my main SSID broadcasts perfectly fine. there is only one option on the access point c...
Q. How many 521 AP (standalone mode) can be supported on the Cisco Configuration Assistant? Some documentation says 3 on other says 10. Just want to provide a correct solution for the client.A: It used to be 3 standlone APs with CCA, and 6 with one c...
Hi. We are a very small organization that uses wireless connection. We use a Linksys router, with 4 PC's connected. We increased to 6 employees and now the connection is constantly on and off (worst than before). Our IT consultant suggested us to go ...
Welcome to the Cisco Networking Professionals Connection Small and Medium Business Forum. This conversation will provide you the opportunity to discuss Small and Medium Business technology issues. We encourage everyone to share their knowledge and st...
