Setting up a cluster of 3 Wap351 with PoE
in_copy
Hello, I have a question aboute building a simple wireless cluster. I intended to use 3 Wap351 acces points, powered via PoE,  Just want  to connect them as a chain with cat.6 Lan, using PD and PSE connections. I know, that PoE+ is provided by this device, but does WAP 351 have an UPoE technology, can it pass through enought power for another acces point? Distance between  first and second WAP351 will be aboute 15meters, and between second and third - 27 meters. Maybe PoE+ will be enought? What kind of power source and power injector should I use? Thanks for any sugestions.
0 Replies 0
