02-13-2013 07:27 PM
i have plan to deploy cisco WAP321 on my customer, and after rading the document about WAP321, it said the WAP321 support for VLAN ID feature, but i cant find whether it support for trunk port because i would like to connect the WAP 321 LAN port to the cisco SMB switch SG300/SG200. is the trunk port already enable on the WAP 321 LAN port so i dont need to configured it or not ??
need your support and asisstance
Solved! Go to Solution.
02-13-2013 07:37 PM
Hi Bram. Yes it supports the trunk. You configure the untagged vlan on the lan setting. Vlans with either switch is no problem.
02-14-2013 05:53 PM
Here is a topic that answers that question.
https://supportforums.cisco.com/thread/2196501
If you need help, let me know. I can make screen shot using a WAP121 (its what I have available...)
-Tom
Please mark answered for helpful posts
02-13-2013 07:37 PM
02-14-2013 05:49 PM
thanks for the reply,
so i need only to set the trunk port on the switch right ?? btw this is my first time working with cisco SMB devices, is there any big differences between the SMB and the enterprise devices, especially for the command
02-14-2013 05:53 PM
-Tom
02-14-2013 06:04 PM
thanks for the link Tom
