Unknown ip address for WEB admin panel
MikeBelkin
Hi guys!
I have 9 AP i network. Ip addresses are below in screen shot.
But ipaddress of ciscobisiness.cisco is other - 192.168.11.45
So i can't get access to Web admin panel with any of AP ip addresses from list above.
I can see ip address of ciscobisness.cisco and it is 192.168.11.45. If i put this ip into browser i get access. But what is address? Ip of web panel in administrator guide is same as Primary AP. But i have different. Looks like ip address web interface has its own ip.
Any suggestions?
MikeBelkin
As resume:
I can not find this in documentation.
But i found this video explain tis feature:
https://www.youtube.com/watch?v=IO17RhUkiJM
This screenshot shows where is this setting:
6 Replies 6
@MikeBelkin
192.168.11.45 is a virtual IP  and make all Sense to be this way. If cisco uses an IP from that list and the access point crashes, your access to dashboard would be gone.
Those IP you can use to access the Access point itself
MikeBelkin
Thanks! Where i can read about this virtual AP? There are some settings for this?
MikeBelkin
There is no matches about virtual ip or virtual ap in this guide
You can use the Google. You might find something.
MikeBelkin
As resume:
