Urgent: AP is not broadcasting SSID
osman869
I have  CBW 240 AC Access point and it shows me operational status is down It was working earlier I just increased the 5GHz channel width from 20 to 40 but I reverted back.
Still I am unable to see the SSID.
Any help?
marce1000
 - Check the logs just after the 240 has booted , check for errors related to wireless or insufficient power provisioning (possibly)
 M.
I Reset the APs and it seems to be working.
However, these Aps are on the latest firmware (10.6) very but abnormal
behaviour. I am not even getting a good speed even though I use the 5Ghz
band.
