Hello!
This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.
Virtual Assistant- Discover support content and options for your gearSupport page index - Contains a ...
We bought a WAP371 Wireless access point in order to create 2 Wifi access points. One for our internal usage, and another for guests with limited access. But I'm struggling configuring the whole thing.
As far as I understood I have to crea...
Hello,i am struggling to set up an ACL inside the GUI of my 140AC access point.How is this meant to work ? If i have more than one rule, are they processed from top to the bottom ? If so, how can i change the order of the rules after implementing the...
When I used tagged VLANs on the SSIDs the performance is extremely slow (barely 1.5 Mb/s transfer rates) even though Sessions page shows the client connected at full speed. If I change the SSID to the untagged VLAN ID then I get full speed transfers....
Alright, so looks like the WAP371 is placing what should be tagged traffic onto the native VLAN. Was wondering why I was getting connection drops, so I checked my syslog and found IP Spoofing detections on my SonicWALL as well. This is causing all ...
Please, I don't have a POE switch, I need to hook up a CBW140AC using an RJ45 to POE adapter,I need to know what voltage this adapter needs. Could someone please pass some information?
We have 4 clustered Cisco WAPs deployed in our office, devices are frequently experiencing disconnection to the WAPs. When I ping the IPs of 4 WAPs it has good returns. But some of the APs led keeps on cycling Green, Red and Amber even if there is al...
Hello,in the last 10 days i have very low bit rates on my devices. on AC and on N mode, same with 5GHz and 2.4. My devices barely reaching 190Mbps data rate and when i am testing with IPerf the maximum throughput i get is 60Mbps actual speed. This w...
I have two WAP371 access points. Each is on it's own VLAN plugged into a cisco RV320 router. I can join the wifi network on each WAP. I'm trying to log into the WAP to configure it. I know the IPs for the WAPs and I double checked by looking at t...
Hi there,I have purchased 6 WAP125 for our office.I've set them up on the 5ghz only, POE, assigned them all the same SSID with the same password and updated the firmware to 1.0.4.3My issue is when adding the 5th one it will connect for a bit and then...
Hello,I do now own for some time (+- 1.5 years) a RV340W router.In manny perspectives it works great, LAN connections never gave any instabillity or problems running multiple VLANS, but from time to time the wireless network stops connecting most of ...
Hi everyone,I am trying to understand how should this feature be enabled/configured.There are two 150s and one 361 that I would like to have this feature enabled and correctly configured.I think I got the first configuration right "Roaming Table", it...
ho installato un CBW 240AC con firmware 1.0.6.1.0ho aggiunto un Mesh CBW143ACMspesso cade la connessione e non permette di navigare e di utilizzare i dati presenti in lan. abbiamo un gestionale su server interno SQL e l'app per smartphone non riesce ...
I need to confirm that the 2nd Ethernet port on a 240AC AP is pass thru to another device that does not need POE? Thanks,. Len LevinBusiness Systems ConsultingPlymouth, MA 02360
