Dear Community
Iam kind of annoied right now. For the last 10 years it was easy for me to setup Cisco APs for customers.
The setup was always the same. Two VLans Routed on the Router with DHCP enabled on the Router, a trunk to the Accesspoint, two SSIDs with the right VLAN Tag.
For some reason, i cant get this simple setup working on a 140ac.
Under the WLAN SSID "VLAN and Firewall" trun VLAn Tagging On and put the right vlan ID inside,
but it doesnt seem to work. Do i also need on of these stange RLANs?
Is there anything im Missing?
Thanks and Regards
Jan
