WAP150 : station deauthenticated
KDG_work
Hi all
There is problem with WAP150(version : 1.1.0.9)
Client unable to connect AP
cf) radio 2(5Ghz) disabled
Please help
Martin Aleksandrov
First off, please upgrade the firmware to the latest one 1.1.3.2 https://software.cisco.com/download/home/286286263/type/282463166/release/1.1.3.2
The 1.1.0.9 is quite old from 2017. Try with the upgraded WAP and post your outcome.
Martin
Thank you for your answer.
one question before upgrading to firmware.
I am operating two WAP150 (Version : 1.1.0.9). one of the  WAP150 causes this issue.
(The other one is normal)
What caused the problem?
You might hit a bug with the firmware which is most likely the case.
