wap200 e no hardware reset
longview12
Hello is the first time i have cisco
I can't do hardware reset in wap 200e
I try as the manual said but nothing
When i connected with lan said there is no lan in my pc in order to acces the ip.
Please any suggestions
Thanks a lot
Eric Moyers
Level 7
Level 7
Hi, My name is Eric Moyers. I am a Network Support Engineer in the Cisco Small Business Support Center. Thank you for using the Cisco Community Post Forums.
When you hold insert a paper clip or wire into the reset button, hold it down for about 35 to 40 seconds. At that point the unit will be reset to a default IP of 192.168.1.245. If the network that you are adding this to is already using the IP scheme of 192.168.1.X, then simply add this to the network. Put the IP 192.168.1.245 in your browser and you should be able to get to the GUI interface for setup.
If you are using a different IP scheme, then you would connect the WPA200E by Ethernet cable directly to a PC. To do that, you have to set your PC to a static IP address, something like 192.168.1.100 is fine. Then you can open a browser and type in 192.168.1.245 and you should be able to get to the GUI
interface.
As you make your setup changes, I would make all of them and then as the last thing I would change the static IP of the WAP200E. That way when the device reboots, you should be able to hook it up to the existing network and be connected.
After all of this, don't forget to reset your PC back to automatic DHCP.
Please let me know if this helps.
Να έχετε μια καλή μέρα!
Eric Moyers
Cisco Network Support Engineer
SBSC Wireless and Surveillance SME
CCNA, CCNA-Wireless
1-866-606-1866
11 Replies 11
Eric Moyers
Level 7
Level 7
interface.
Eric Moyers
CCNA, CCNA-Wireless
1-866-606-1866
Στις 21/12/2011 4:53 μμ, ο/η emoyers έγραψε:
Home <>
Re: wap200 e no hardware reset
created by Eric Moyers
<> in /Small Business
Wireless/ - View the full discussion
Hello
Thanks a lot for your help and your email but nothing happen
I did everything you said and still i can't reset it to factory default.
I am waiting your news
Καλα Χριστούγεννα
Dear Mr Eric Moyers
The problem is still here
I can't have access by lan only wireless but write that wireless acces is not alowed
Is there any other way to do this in order to make factory reset
Καλα Χριστούγεννα
Best Regards
Kostas
longview12
Dear Mr Eric Moyers
Thanks a lot for your answer
I did everything you said but still i can't have factory reset is there any other way to do it
i am waiting your news
Best Regards
Kostas Kaimasidis
Kostas,
The WAP200E has a reset button on the back of the unit (top-middle) of the device. To the right of the whole says (RESET).Since this is an external AP then could possibly have a screw inside the unit. Please take the screw out, now with a paperclip press the button inside the screw whole. You should feel the spring load on your paperclip. Once you are sure it’s working correctly. Press this reset button down for 30-45 seconds. This should take your AP back to factory reset settings. WAP200E is powered via PoE so you’ll need to leave it plugged into a PoE switch, first you can check your DHCP server and see if you have an IP address that matches the MAC address of the AP and access it with this address. If you don’t see an address in your DHCP server, then assign your pc a static IP Address of 192.168.1.20/24 and try and connect to the AP @ 192.168.1.245.
Hope this helps,
Jasbryan
Dear Jasbryan
thanks a lot for your email and your help.
i did all this you advice me but i can't login by wired with ethernet only
from wirelless and write me that you can not  login web server wirellles
Is there any other way to make just a simple factory reset
has anybody has the same problem before
Thanks for your help
kostas,
Call into Cisco Small Business Support Center @ 1-866-606-1866 and see if you're device is still under hardware/software warranty. If so open a support case and have the next available engineer assist with your issue. If engineer determine it's defective we can set up an RMA for you.
Jasbryan
Dear Jasbryan
Thanks a lot for your email and your help
My device is only 1 week new
What is RMA ?
Thanks a lot
We wish you a Happy New Year
I am waiting your news and your Help.
Kostas
Kostas,
RMA (Return merchandize Authorization) please call the support line for further trouble shooting.
US&Canada 1-866-606-1866
If you're outside the US please click on link below for support numbers
http://www.cisco.com/en/US/partner/support/tsd_cisco_small_business_support_center_contacts.html
Jasbryan
Dear Jasbryan
We wish you a happy New Year
I can't have access
I have to return it back to the shop.
Kostas
