Hello!
This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.
Virtual Assistant- Discover support content and options for your gearSupport page index - Contains a ...
My Blackberry Storm 2 is able to connect via Wi-Fi (WPA2-Mixed) to either the WAP200/WAP2000 but it is then unable to connect to the Blackberry Enterprise Services (BES). If I replace the WAP200 & WAP2000 with a WAP54G it connects to the WAP easily ...
I have the 881 connection to our network through a vpn. Authentication, etc. works. I have the Wireless AP up and working. What I want to do is control the 881 AP through the VPN with WCS. What CLI commands am I missing? The WCS is not seeing the ...
Hi Everybody,we want to extend our Wireless Network existing of 10 x AP541N with a hotspot solution. Does anyone know if there are any solutions available.We also have an old Zyxel G-4100 Hotspot incl. Printer. Is there any chance to implement this ...
Hi, first time poster I've just purchased 2 WET200 wireless bridges for our organisation, with the intention of using them to create a wireless bridge between 2 buildings.I've followed this guide here:http://www.cisco.com/en/US/products/ps10047/produ...
Hi allI have an iPad 1 with newest iOS version connecting to a WAP2000 device setup with WPA2 Personal, MAC Address Connection Control enabled and SSID Broadcasting disabled, VLAN enabled (WAP2000 is running on latest firmware). Everything works w...
Hi guys,Here is what we have: - 1 UC500 - 1 Switch- 3 AP541's connected to the switch called AP1, AP2, AP3.Here is what we want: - Just the data on the wireless, no voice. - Single SSID- Seamless roaming between APs for the clients.Here is what I ask...
HelloI need your advice on whether power Injector for Aironet AP’s can be also used for SB WLAN products. Is AIR-PWRINJ4= compatible with WAP200??Any advice would be very appreciated. Best Regards,Allan Kim
We are looking at purchasing two of the WAP4410n Access Points to add wireless in one building, and possibly replace Wireless G in another.In our building already configured, we have POEs set up and this has helped centralize everything that has to b...
The SA520W product is used as a WiFi Router with DHCP server enabled. The problem is that from time to time the users can't see each other in the network until I reboot the router.After reboot all is fine sometimes even for 1 week but sometimes only ...
Good Morning,I have a Linksys WRT 600N Wireless Router and have been very pleased with its performance. It has been online for a few years now and in computer years that makes this device a dinosaur. I have been looking at the new WRVS4400N. Can some...
Hi,I have an SA520W firewall, and am implementing a new AP541N. On the SA I am using port 4 to connect the AP. Trunking is on with Vlan 1 and 25.Connecting the AP I am able to use VLAN1, however when I assign a new VAP using Vlan 25, I only receive I...
Hello,I have WAP4410N with firmware 2.0.4.2I want to configure it this way.1-I have this external 12db antenna connected to one of WAP4410 3x3 antenna connections PLUS the other standard 2.2-I want the WAP4410 to connect to an accessible Wifi SSID se...
Hello Everyone,We are considering order the AP541N for our network. A few questions...1). Are there multiple models of the AP541N? or just one cisco part number?2). I am assuming the basic antenna comes with it. Please advise if this is something tha...
hi for all,Im Michel from brazil,I have a problem with wap4410n.. every day, the access point in variable time kick all wireless clients (red X in network status) and i need to reboot the equipament to connect again. the equipament do not stop resp...
Does anyone have a best guess answer as to when we might see a 802.11n wireless bridge similar to the WET200? The current product has been out for a while, and I would love to replace my D-Link DAP-1522, but it's 802.11n and has GigaBit ports... get...
