WAP321 - Captive Portal login URL (SSL)
tnrrnt001
currently, the Captive Portal redirects me to its IP address for login (https://192.168.42.20/cp.cgi?action=captive). Is it possible to redirect to fully qualified hostname? The problem is that by redirecting to IP address, you cannot use (wildcard) SSL certificate, as it doesn't match hostname. However, purchasing several different certificates just to provide for all APs seems a bit excessive..
Thank you,
Pavel
5 Replies 5
jeffrrod
Level 4
Level 4
Dear Pavel,
Thank you for reaching Cisco Small Business Support Community.
Please refer to the Instance Configuration section in the admin guide, p.147,  where you can choose between HTTP or HTTPS as the Instance protocol and where you can enter a fully qualified domain name under "Redirect URL";
http://www.cisco.com/en/US/docs/wireless/access_point/csbap/wap121/administration/guide/WAP121_321_AG_en.pdf
I hope this answers your question and please let me know if there is any further assistance I may help you with.
Kind regards,
Jeffrey Rodriguez S. .:|:.:|:.
Cisco Customer Support Engineer
*Please rate the Post so other will know when an answer has been found.
Jeffrey Rodriguez S. .:|:.:|:. Cisco Customer Support Engineer *Please rate the Post so other will know when an answer has been found.
the Redirect URL is the URL you are redirected only after you have successfuly logged in through Captive Portal (which will still be displayed by its IP address), isn't it?
What I need to modify is the address of the initial login page where you are asked for credentials.
Pavel
Dear Pavel,
I understand your point now and I see no way to modify that GUI feature.  You can try contacting the Small Businesss Support Center directly to see if they have an idea how to edit that;
https://www.cisco.com/en/US/support/tsd_cisco_small_business_support_center_contacts.html
Please let me know if there is anything else I may assist you with.
Kind regards,
vvijaysa
Hello Telian,
My name is Vijay S. Venkitachalam. The below link has all the captive portal configuration articles on wap321/121. Please have a look at it and let me know whether it helps or not.
https://supportforums.cisco.com/docs/DOC-32642
Hello Mr. Rantorski,
My name is Eric Moyers. I am a Network Support Engineer in the Cisco Small Business Support Center. Thank you for using the Cisco Community Post Forums.
Currently the IP Address you get forward to is the only option available because of the way the program is coded.
There is no option available for changing the current address.
I would suggest calling to one of our Support Centers and having a case opened for a "Feature Request". But I would stress once it is made, it would still have to be approved to progress further. On the front lines we have no control over that only the development teams do.
Eric Moyers    .:|:.:|:.
Cisco Small Business US STAC Advanced Support Engineer
CCNA, CCNA-Wireless
866-606-1866
Mon - Fri 09:00 - 18:00 (UTC - 05:00)
Cisco Small Business Support contacts: http://www.cisco.com/en/US/partner/support/tsd_cisco_small_business_support_center_contacts.html
