WAP321 POE not working W lan and inline POE adapter
getRdone
I am installing a WAP321 that I'm having a tough time with getting LAN access to work.  Does this device require a special cable when connecting directly to a non POE switch?
I can get the device to work with a seperate power adapter and connect to my local LAN with a normal patch cable.
I can get the device to work when I connect to POE when the device is connected to a downstream switch away from our main Cisco switch and using a inline POE.
I can get the device to work on a downstream cisco switch that has a POE port and just directly plug into it with a patch cable.
I can not get the device to work when using a inline POE and connecting directly to our company switch. I have tried this on several different switches with different cables and inline POE adapters.  This has me baffeled.
Any help here? I'm using regular patch cables.
Thanks in Advance
getRdone
Ended up being a bad PoE adapter. PoE was PoS.. Lol....
Thanks all for the ideas here.
getRdone
roadrunner992
what does PoS mean?
