WAP321, STA is leaving IBSS or ESS
Michiel Beenen
Level 3
Level 3
Hello all,
Been using the WAP321, 2 of them in our home for quite some times but about once a week and today 3x after eachother i see this in the logs:
Oct 25 2013 15:09:17infohostapd[2452]The wireless client with MAC address dc:85:de:48:a8:12 has been successfully authenticated.
Oct 25 2013 15:09:17infohostapd[2452]wlan0: WPA STA dc:85:de:48:a8:12 pairwise key exchange completed (WPAv2)
Oct 25 2013 15:09:17infohostapd[2452]wlan0: IEEE 802.11 STA dc:85:de:48:a8:12 associated with BSSID 44:2b:03:8b:ea:00
Oct 25 2013 15:09:17infohostapd[2452]wlan0: IEEE 802.11 Assoc request from dc:85:de:48:a8:12 BSSID 44:2b:03:8b:ea:00 SSID Mnet
Oct 25 2013 15:09:04infohostapd[2452]wlan0: IEEE 802.11 STA dc:85:de:48:a8:12 deauthed from BSSID 44:2b:03:8b:ea:00 reason 3: STA is leaving IBSS or ESS
Oct 25 2013 15:01:51infohostapd[2452]The wireless client with MAC address dc:85:de:48:a8:12 has been successfully authenticated.
What could be the reason of this? Our macbooks/iphones completely disconnect and then 10 secs later reconnect, while working on them.
7 Replies 7
Eric Moyers
Level 7
Level 7
Hi, My name is Eric Moyers. I am a Network Support Engineer in the Cisco Small Business Support Center. Thank you for using the Cisco Community Post Forums.
It looks like your WAP may be set to auto mode for the channel. You will get disconnects like that when the WAP automatically changes  channels then once it is set the wireless device(PC, MAC, etc) will  automatically reconnect. If the WAP is in a congested wireless environment, then your WAP could spend more time hopping channels than allowing connections.
Chk that and if it is set it to a static channel and see if the same thing still occurs.
Eric Moyers    .:|:.:|:.
Cisco Small Business US STAC Advanced Support Engineer
CCNA, CCNA-Wireless
866-606-1866
Mon - Fri 09:00 - 18:00 (UTC - 05:00)
*Please rate the Post so other will know when an answer has been found.
Hello Eric,
Thank you for the fast reply
We already have static channels set on each Access point, 11 and 6 on the second.
They are in single point setup mode but i dont have auto assign channels enabled.
Automatically re-assigning channels << disabled.
So I guess that cant be it.
Seems im not the only one with this problem, software bug?
Hello, my name is Jonathan and i am one of the Engineers here at Cisco Small Business,
I apologize for the long delay in answering your question, by now i assume you found out what the reason of your issue was, if you have any questions regarding this unit or any other you can contact us back. thanks
bigron48127
Michiel,
I came across the same problem as you. I was connecting a wireless client that did not support 802.11n to my radio broadcasting 2.4GHz. Normally, 802.11n broadcasting on a 2.4GHz radio is backward compatible with 802.11b/g clients, but for performance, I had my 2.4GHz radio only set to 802.11n. Which was causing these same errors: " deauthed from BSSID [RADIO MAC] reason 3: STA is leaving IBSS or ESS".
-RJ
istvan.bajko1
Jul 4 2016 11:05:11 info hostapd[1104] wlan0vap1: WPA STA cc:25:ef:0b:83:83 pairwise key exchange completed (WPAv2)
Jul 4 2016 11:05:11 debug hostapd[1104] wlan0vap1: IEEE 802.11 STA cc:25:ef:0b:83:83 associated with BSSID 54:a2:74:12:c9:41
Jul 4 2016 11:05:11 debug hostapd[1104] wlan0vap1: IEEE 802.11 Assoc request from cc:25:ef:0b:83:83 BSSID 54:a2:74:12:c9:41 SSID WebEyeGuest
Jul 4 2016 11:05:11 debug hostapd[1104] wlan0vap1: IEEE 802.11 STA cc:25:ef:0b:83:83 deauthed from BSSID 54:a2:74:12:c9:41 reason 3: STA is leaving IBSS or ESS
Jul 4 2016 11:05:11 debug hostapd[1104] wlan0vap1: IEEE 802.11 STA cc:25:ef:0b:83:83 disassociated from BSSID 54:a2:74:12:c9:41 reason 8: Sending STA is leaving BSS
Jul 4 2016 06:08:20 debug hostapd[1104] wlan0: IEEE 802.11 STA b8:86:87:55:5a:9b associated with BSSID 54:a2:74:12:c9:40
Jul 4 2016 06:08:20 debug hostapd[1104] wlan0: IEEE 802.11 Assoc request from b8:86:87:55:5a:9b BSSID 54:a2:74:12:c9:40 SSID WebEyeOffice
Jul 4 2016 06:08:20 debug hostapd[1104] wlan0: IEEE 802.11 STA b8:86:87:55:5a:9b deauthed from BSSID 54:a2:74:12:c9:40 reason 3: STA is leaving IBSS or ESS
same problem.
Maybe is a soft error?
Hello all,
I had the same issue with some laptop into my company with WAP371.
I have solve the problem by changing 2.4Ghz mode to 802.11b/g only. It works great for all computers now!
