WAP371 cluster + one WAP371 in WDS bridge
kasper
I have 6 WAP-371's running in a cluster. Now I would like to add one more AP without wire as wiring is a little difficult on this one floor. Is that possible? I have unsuccessfully tried WDS bridging.
Thanks!
/Kasper
jonrodr2
Hello, my name is Jonathan and I am part of the Small Business Department.
I apologize for any inconvenience with the unit, the single point setup is not related to the wds but you will certainly be able to connect some units for Roaming using that feature you just have to put the remote Mac address of the devices that you will be connecting and that should give you access to the network.
As well, feel free to contact us to open a case if you need assistance.
https://supportforums.cisco.com/community/4626/small-business-service-and-support-country
Thank you for your reply, Jonrodr2.
So this means, that I enable WDS on the AP in the cluster that is closest. And then add the mac-address of the AP that I want to use as roaming AP?
Or is the other way around? I add the MAC address of the cluster AP in the roaming AP?
Thanks!
