07-12-2015 08:57 AM
Does anyone know how to mount a WAP371 without the ethernet cable being visible?
Cisco designed the ceiling mount very poorly.
10-22-2015 07:23 AM
Agree with you, the connector is at the bottom and is visible. The 500 series is much better designed to hide the connector.
11-02-2015 02:52 PM
Hello there,
Have you considered using a right angle Ethernet cable such as this one?
http://www.amazon.com/Tripp-Lite-Gigabit-Molded-N204-010-BL-DN/dp/B005WKIR44
It could run straight up into a hole in the ceiling and plug 90 degrees to the WAP hiding it effectively
Best,
-Patrick Ayers
11-03-2015 12:37 AM
Nice workaround
