After noticing no clients associated on 2.4GHz, I discovered that my WAP371 stops transmitting on Radio2 (2.4GHz) while 5GHz works OK. A reboot brings it back to life for a short while. This can be clearly seen with a Wifi analyzer app on the tablet.
I do have a schedule, but Scheduler Association shows the radio is enabled:
This is the schedule. Basically I want it off between 1am and 7am.
Nothing obvious in the log.
Firmware is 1.3.0.7.
It is powered by an external power supply through the socket.
Do I have a hardware problem?
