09-06-2012 02:07 PM
I just recieved a WAP4410N and managed to log in to the web interface. It is not allowing me to change many settings. I try to change the wireless network mode and click on save and it goes back to disabled again.
Please help.
P.S. I have just upgraded the firmware to 2.0.3.3 and tried to set it back to the factory defaults. neither worked.
Solved! Go to Solution.
09-06-2012 02:19 PM
Hi Ryan, please try using different internet browsers and ensure your java is on the latest update. If it is possible, please try to upgrade to the 2.0.5.3 code as well.
-Tom
Please rate helpful posts
09-06-2012 02:19 PM
-Tom
