Showing results forĀ
Search instead forĀ
Did you mean:Ā
WAP4410n problem
polgarattila
Hello
My WAP4410n working normally and now try open the admin web page and get this
pink backwall
404 Not Found
File not found.
What is problem and possible resolve this?
thanks
Ingrid Aragon
Make sure you can ping the IP address, the first workaround that I would suggest is to use a different computer, try to use different browsers. If that does not work, try a factory reset.
