03-01-2019 11:16 PM
Ran into an interesting problem with a WAP4410N that I haven't used for a while. I couldn't remember the password I'd originally given it; so I reset it to factory defaults.
When it rebooted; it picked up an IP address (wired side) from the WRVS4400N router's DHCP. Using that IP in Firefox, I was able to log in via the default user/password of admin/admin.
The issue, however, is that when I change the WAP LAN IP from Automatic to Static; and change the actual IP; after the router (automatically) reboots the login is no longer admin/admin. Or whatever I might have changed it to; if I changed the password *first* prior to changing the IP.
I've not performed *exhaustive* checks; but it seems like this *only* happens when the actual IP is changed via the administration menus.
I upgraded the firmware to the latest available (unit was a bit back leveled); but that did not fix the situation.
I would *like* the WAP to *preserve* password settings across *any* other configuration change other than resetting to factory defaults.
Also, there's a big issue with time. One can't manually set a time later than 2015; and NTP doesn't seem to work either. How does one "bring the WAP" into the present?
WAP serial # is ASK07HA00345. According to Cisco FindIT; it's still "Under Warranty"; whatever that actually means.
Any ideas on how to fix either/both of these problems?
03-01-2019 11:43 PM
Some interesting additional data: I had enabled ssh access prior to changing the IP mode/address. The new password for the admin account *worked* with ssh. Invoking "get password" showed the correct password. Doing a "set password" to the *same* password caused the web interface to again accept the admin/password combination that worked *prior* to the change of the IP mode/address and the automatic reboot that followed.
So it seems that somehow changing the IP mode/address via the web interface somehow corrupts the web login; but *only* the web login.
It's late; I'm tired; but perhaps I'll get a chance to see if trying to set a current date or enable NTP works if done through the ssh shell commands.
03-02-2019 12:00 AM
And it *does*.
Interesting. It appears one can do things via ssh that the web gui won't allow. Too bad as far as I can see there's no actual *documentation* on configuring one of these units via ssh vs web.
On another note; on my WRVS4400N one can't log out of the web interface. It's a "void" button.
I wonder if there was any "quality assurance" tests done with these device's firmware upgrades before each was made available; or if that's the role of the individual owner/user? LOL.
