WAP561 - Apple Bonjour trouble
kmartin59
I have two access point WAP561 with the last firmware ( 1.0.4.4). I have big trouble with apple Imac & Macbook.
-Apple disconnecting
-Bonjour Discover didn't work after 2 days
I must reboot every 2 days the AP for workaround the problem.
I had try new settings :
-disable Green ethernet mode
-Fix Multicast rate
-Fix channel
-Disable Bonjour
The bonjour discover still not working after 2 days ...
Thanks for your help
Michiel Beenen
Level 3
Level 3
What do you mean with bonjour discover exactly? airplay?
We have Bonjour enabled on all access points and airplay devices show up fine (though sometimes it can take a bit).
Try upgrading to the latest firmware 1.1.0.4 and re-enable bonjour on the access point and leave Green ethernet disabled.
