Hello!
This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.
Virtual Assistant- Discover support content and options for your gearSupport page index - Contains a ...
Hello,after having been dissapointed by the the high jitter and and slow performance of the WAP321, I have decided to roll out a configuration with four new WAP561 devices to deliver good coverage to use VoWiFi.Unfortunateley the WAP561 deliver a ver...
Hello, Im a owner of a Chiringuito ( restaurant on the beach) in spain, and i just saw on Facebook that you can use a Cisco router to fix your facebook page as a logion for the guesst.And my quiestion is if i can buy this Router in spain and if it wo...
PID VID: WAP4410N-E V02 Software Version:2.0.1.0 We have one of these units runing 2.0.1.0 and I am trying to upgrade it to the latest 2.0.7.4When I select the file it seems to start the upgrade (all the lights go out on the front of the unit) but w...
Dear Support team, I am facing this problem since a few months now. As per my initial conversation before purchasing WAP440n device. I called Cisco and they told me that it will work with non Cisco router. After that I bought it. Now when I try to co...
We have an ap541n-a-k9 wireless unit. When a user connects thru the wireless device into our network the laptop grabs a DHCP IP address from our intranal DHCP server. However, we are running out of IPs. Can the ap541n unit be configured to act as ...
i have issue with my AP 1602i SAP i wanna to configure server dhcp to allow ip addresses dynamically so can any one told me if it's possible to make my access point as server dhcp for the client dhcp
Any idea on this? it keeps doing this over and over.Jun 3 2014 14:29:07errmDNSResponderERROR: getOptRdata - unknown opt 65002 Jun 3 2014 14:29:07errmDNSResponderERROR: getOptRdata - unknown opt 65002 Jun 3 2014 14:29:06errmDNSResponderERROR: getOptR...
I have two WAP4410N. One of he accesspoints is connected to our wired LAN, called by now AP1. The other accesspoint is connected to the first accesspoint by WDS (Client mode) called now by AP2. I have upgraded both accesspoints to firmware 2.0.4.2. B...
We do have 4 (four) Cisco WAP321 in one of our offices. Things were working pretty well for a while. Then clients are randomly being disconnected from the AP (Windows laptops, iOS and Android phones and tablets, etc). Looking through the logs, I not...
Hi GuysWe have 3 WAP321 units in the office, and while most of the time they work ok, we have had some issues where by users cannot connect. I have searched the forums already and found a related issue (the answer appeared to be to turn off TKIP and ...
Hello everyone. We have 18 AP541-Ns and 2 WAP551s at our office. And we want to use them by cluster. My question is that, can these Access points support each other? If someone have any idea on that, please assist us. And another one question:They ca...
we have 6 WAP4410N-E V02 devices working, but periodically they stop working and after reboot they work again, maybe because there isn't traffic?.Last firmware installed (2.7.0.4). Any workaround to solve it?configuration?
Hi guysI have a WAP121 AP, and i want to be able to setup a guest SSID along with my full access SSID. The guest network should only be able to access the internet.I have the AP plugged into a single port on a Netgear GS728TP smart switch.I know i ha...
Hello, I have two access point WAP561 with the last firmware ( 1.0.4.4). I have big trouble with apple Imac & Macbook.-Apple disconnecting-Bonjour Discover didn't work after 2 daysI must reboot every 2 days the AP for workaround the problem. I had tr...
