WAP571 VLAN issue
heiner.ohm
Hello Cisco Users,
i have a Problem with a WAP571 Cluster with 3 APs.
On the Cluster are 2 SSIDs (Internal, Guest).
Internal: VLAN1 untagged
Guest: VLAN 108 tagged
The Internal SSID works fine, but with the guest network we have a big Problem:
When i'm connected to the Cluster Controller, everthing is fine. But the member APs dont seem to handle the VLAN traffic. I can connect but i dont get a IP by DHCP. When i roam from the controller to a member, my test ping stops working.
I have this issue at a Customer. So i replaced our WAP371 Cluster for testing withe three new WAP571 an run into the same issue. So im sure it is not a VLAN issue in my network.
I´m not sure. Maybe it worked with 10.0.1.10 and stoped working with 10.0.1.11, but a swap back to 10.0.1.10 made no change.
When i change the VLAN on the Guest network to '1', everthing works finde...
Some ideas?
heiner.ohm
Solved!
The VLAN Options at "LAN -> VLAN Configuration" where _not_ synchonized to the Cluster members. We had to add this VLAN on every AP.
@cisco Why??? Can you please write a Information on the VLAN an Networks Page, and in the Manual in the VLAN Section?
Best Regards,
Heiner Ohm
My name is Iliya Gatsev from Cisco Technical Support Team.
I think it would be best if you could call our support line and create support case.
Iliya Gatsev
Cisco STAC Network Engineer
Together we are the human network .:|:.:|:. CISCO
