Hello!
This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.
Virtual Assistant- Discover support content and options for your gearSupport page index - Contains a ...
Dear all hello!.
Trying to solve a problem, would like to hear some reccomendations from community...
we have two WAP150 AP's connected to Mikrotik router, and after some uptime good working (3-5 days) (Radio 1) interface stops working. This can ha...
My wireless controller is configured with AAA security for Guest Internet access. The Cisco ISE server is in use for AAA. However, I also want to enable WPA2 with PSK. However, when I do so, I receive error as shown in attachment. I have atta...
Hello,I just got an WAP371 yesterday. I am using the SB-PWR-INJ2 to power it over PoE. I updated the firmware to the latest version 1.0.1.5. I am experiencing terribly slow performance with the device. It is supposed to be replacing a N450 access poi...
Hi folks,The admin guide for the WAP4410N, explains the default setting for the Wireless Network Mode field:"B/G/N-Mixed—(Default) Connects all the wireless client devices at their respective data rates in this mixed mode."What does this mean exactly...
Hello. We have bought several WAP351 access points and have some problems connecting with a MAC. In the log of the AP I see the following
Feb 4,2016 14:35:48 info hostapd[1583] Station aa:bb:cc:dd:ee:ff had an authentication failure, reason 20Feb 4,2...
I have an issue with my WAP and the RADIUS server not working well together to account for users.
I brought the issue up with the Server developer and they said that:
"TekRADIUS receives RADIUS accounting packets with Acct-Session-Id = 00000000-00000...
We had just purchased three Aironet700 wireless access points and upon setting them up discovered the devices provided extremely slow access to the Internet. We have cable Internet service from Airtel and when attached to Ethernet or an older wireles...
I have Wireless Controller 5520. Is there a way that I could configured it for APs to increase their wireless coverage if a near AP goes down?
Qamber
Hi members, I have a customer who owns a Pub and wants to setup wireless access for its guests.I have ordered a seprate internet connection and wanted some advice on a solution. The site is quite large but typically each area is isolated from the nex...
Hi all,
I have just checked that Controller 5520 to check the AP Performance, I found that one AP is suffering from high channel utilization and high interference. Can any one teach me is it a normal case?
Number of user connected: 13
Channel Ut...
WAP4410N Software Version 2.0.7.4. Firefox gives the above error and will not connect. IE gives a similar and certificate error but will let me connect.Is there an upgrade or fix to this?Thanks for your help.
We have been using WAP121 devices in our customer installs for some time. We appear to be experiencing problems on newer installs where the customer is using WEP (for whatever reasons, changing away from WEP to resolve the problem is not a solution a...
Hello, I hope that a small business wifi router expert will help me tonight ASAP. My present Cisco router died tonight and I need to order one in the AM. Would someone or several please give me their thoughts and recommendations on a new business w...
I can't put my new WAP150 in the cluster of WAP321. It's seem that the wap are not compatible.
The versions of hardware are different.
WAP150 : WAP150-E-K9-EU V02 (1.1.0.9)
WAP321 : WAP321-E-K9 V01 (1.0.6.6)
Nicolas
