wirelless router to Access Point
aatish_dani
How Can i Connect wireless router wrt45g2 wirelessly to access point wap4410n ??
I have tried but its not able to get through with the settings. Please let me know the configurations
jasbryan
Level 6
Level 6
Aatish,
The WRT54g2 doesn't support WDS (Wireless Distribution System) so you want be able to wirelessly connect those two device together. Now you can physically plug each device into one other using a Ethernet cable for the connection.
Jasbryan
thanks for the reply. I had called up cisco business support and they told me it would be possible but they would not be able to help me in configuration of wrt54g2 as it is consumer product. Please advice the configuration.
If i plug the device thru ethernet cable. Please advice the configuration
Hi Aatish,
You should be able to plug the AP into one of the four LAN ports on the router and use it as an Access Point. There is no special configuration needed as this is what the AP is designed for.
