06-27-2014 08:24 PM
Where did the WPS 'soft button' and configuration detail go on the WAP561?
There is no WPS Setup under the Wireless menu.
01-20-2015 05:15 AM
Could you please let us know what firmware version are you using?
02-20-2015 09:51 AM
Moin, sorry for the slow reply. I am running -- v1.1.1.06 (2013-12-06, 11:02:37) --
01-20-2015 12:26 PM
My name Eric Moyers. I am an Engineer in the Small Business Support Center.
I have talked to the Business Development Group about this and in the most recent release, 1.1.0.4 it was decided to remove this functionality from our Wireless Access Points. A work order has been filed to also remove mention of this feature from related Cisco Documents.
Eric Moyers
.:|:.:|:. CISCO | Cisco Presales Technical Support | Wireless Subject Matter Expert
Please rate helpful Posts and Let others know when your Question has been answered.
02-20-2015 09:53 AM
WOW. A sad step backward. It is hard to understand, but makes other WiFi vendor options look more appealing.
02-20-2015 10:11 AM
Some of Cisco decision was based on a security flaw within WPS. You can read about that here. http://www.kb.cert.org/vuls/id/723755
Since it is urged that customers disable this feature, I am assuming that Cisco has pulled that from the products for now thinking of customer security precautions.
Eric Moyers
