WPS on the WAP561
Where did the WPS 'soft button' and configuration detail go on the WAP561?
There is no WPS Setup under the Wireless menu.
5 Replies 5
Moin Ilyas
Level 4
Level 4
Could you please let us know what firmware version are you using?
Moin,  sorry for the slow reply.  I am running -- v1.1.1.06 (2013-12-06, 11:02:37) --
Eric Moyers
Level 7
Level 7
My name Eric Moyers. I am an Engineer in the Small Business Support Center.
I have talked to the Business Development Group about this and in the most recent release, 1.1.0.4 it was decided to remove this functionality from our Wireless Access Points. A work order has been filed to also remove mention of this feature from related Cisco Documents.
Eric Moyers
.:|:.:|:. CISCO | Cisco Presales Technical Support | Wireless Subject Matter Expert
Please rate helpful Posts and Let others know when your Question has been answered.
WOW.  A sad step backward.  It is hard to understand, but makes other WiFi vendor options look more appealing.
Some of Cisco decision was based on a security flaw within WPS. You can read about that here. http://www.kb.cert.org/vuls/id/723755
Since it is urged that customers disable this feature, I am assuming that Cisco has pulled that from the products for now thinking of customer security precautions.
Eric Moyers
