Hey all!
When I connect to my router via the default gateway IP address I no longer have access to the configuration options. It just brings up the recovery tool. It will assign IP addresses when I connect via cat 5, but it will not broadcast an SSID. I have tried updating the firmware, but even after running the update it just takes me to the recovery tool. The only options I have are update firmware or reboot.
I thought about using DD-WRT, but this particular router is on the black list for that particular firmware option.
