Hello!
This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.
Virtual Assistant- Discover support content and options for your gearSupport page index - Contains a ...
Hello Everyone,I had some issues with our Accesspoints and decided to update the Firmware as it's discussed in several posts here in the forum.Unfortunately this update from 2.0.4.2 to 2.0.6.1 was crashing the accesspoint eventually.So here's what ha...
Hi all,i have a problem with the AP WAP200, i can't make access to web setup. It gives to me the error "Unauthorised" without asks to me user or pass.I tried to reset the AP and i tried to access with others pc and smatphones but the problem persists...
I'd like to setup a Captive Portal on our WAP321. We will probably have 50 users (although there will probably be less than 10 simultaneous users). What is the maximum number of Captive Portal users (when using the "local" verification option) that...
I have a WAP321 I am trying to set up. It's connected to gi1/23 and the switch system mode is set to router. The rest of the network works just fine.I have an SG500-28p and the port is configured as:interface gigabitethernet1/23 spanning-tree portf...
Hi Randy,We have a situation with 20 4410N's They are connected through a 2960 switch. They runned for about a year with no problems. We use the WiFi system with 10 cisco wireless ip phones, several workstations (5-10) and a few mobile devices.Three ...
Well... I wish I could say the V2's have solved the issue fully. But they haven't.I've had multiple times where different V2's have gone offline until I unplug and re-plug in the network cord again. The frequency seems to be less than before, but i...
I have 4 - WAP 321's in an office all connected to a POE gigabit switch. Each WAP shows connected at 1GB but when I am sitting within a couple feet of the WAP and attempt to transfer a 972MB file it takes around 9 minutes to complete. Anyone have a...
I was wondering if anyone else is able to get their WAP321 to work in Dual channel mode in which the connection shows 300Mbps as the speed. I know this is a theoretical speed but I have tried all the settings and have not been able to get it to do i...
I have an RV110, and I'm interested in extending the WiFi range using its WDS feature.The RV110W data sheet simply states.. "allows wireless signals to be repeated by up to 3 compatible devices",Where can I find these "compatible devices", and has an...
'Cisco AP 541N includes an easy-to-follow graphical user interface (GUI) to guide you through the setup of a guest network. This highly secure guest access solution lets visitors get online without granting them any visibility into your business netw...
Hey all!When I connect to my router via the default gateway IP address I no longer have access to the configuration options. It just brings up the recovery tool. It will assign IP addresses when I connect via cat 5, but it will not broadcast an SSI...
hello everyone, my residential society area is about 200m-300m. In that we have 15 baunglows nd i want to give all the baunglows wireless internet connecitivity.so, please help me in selecting the approprite wireless device, so every member of societ...
Hi. I want to authenticate users with freeradius server installed on external pfsense firewall.I've added GUEST ssid and set security to Dynamic WEP (or WPA Enterprise). My external pfsense freeradius server has ip 192.168.168.50 and listen on port 1...
Hi there, I would appreciate some help or guidance in the right direction.I have an issue with cisco ap514n. Clients connecting to the AP are unable to obtain the IP from DHCP server. If I set a static IP, everything works fine.Network is connected l...
