WRV200 and iPad
aimilios12
Has anybody setup an IPSec tunnel between any kind of iOS client and WRV200? I cannot seem to get the configuration right and certainly does not work over the standard IPad configuration.
jeffrrod
Level 4
Level 4
Dear Aimilios,
Thank you for reaching the Small Business Support Community.
I'd suggest you using IPSecuritas as the VPN Client;
http://ipsecuritas.en.softonic.com/mac/download
Please check on the below document for detailed instructions on how to proceed about it;
https://supportforums.cisco.com/docs/DOC-10266
I hope you find this information useful and please do not hesitate to reach me back if there is any further assistance I may help you with.
Kind regards,
Jeffrey Rodriguez S. .:|:.:|:.
Cisco Customer Support Engineer
*Please rate the Post so other will know when an answer has been found.
Jeffrey Rodriguez S. .:|:.:|:. Cisco Customer Support Engineer *Please rate the Post so other will know when an answer has been found.
Dear Jeffrey,
thank you for your reply, however it seems that I did  not express my problem accurately. I need to establish an IPSec tunnel  between the WRV and the iPad. The sw you suggested is for other iOS  devices and cannot work for the iPad/iPhone sw. Is there another sw I  could use as the Any Connect requires ASA on the other side which as I  understand is not the case for the WRV.
Thanks in advance,
Aimilios
jeffrrod
Level 4
Level 4
Hello Aimilios,
The only other thing I think of is the built in IPsec client feature on these mobile devices that may work with the WRV200 VPN Client Access setup, if you have already tried that with no success I then suggest you to contact support directly to figure something else out.
https://supportforums.cisco.com/community/netpro/small-business/sbcountrysupport
I wish I could be of a better help and please do not hesitate to reach me back if there is any further assistance I may help you with.
Thank you again,
