WRVS4400N DHCP with public/private SSIDs
codysparks
I'm attempting to setup a WRVS4400N with multiple SSIDs:
SSID: private
     WPA2, should have access to wired LAN and internet, and I currently have a Win2008 server running DHCP/DNS on the LAN.
SSID: public
     WPA2, should ONLY have access to internet
Browsing posts here, I've come to the conclusion that I should set up public on VLAN ID 2 and disable inter-VLAN routing in Advanced Routing.  Now, how do I provide DHCP to the public SSID?  Setup->LAN is set to VLAN 1 with DHCP disabled (so the Windows server can handle DHCP), but I don't see where to enable DHCP for the public SSID on VLAN 2.  Should I re-think my configuration strategy, or how can I provide DHCP to the public SSID without giving it access to my internal private network?
--Cody
David Carr
Level 6
Level 6
Cody,
With your setup, Create the vlan and have the public wireless in vlan 2 and disable inter-vlan routing.
I would let the router give out DHCP for vlan 2.
If you go to the lan settings, you can select vlan2 and create a network and DHCP scope for that vlan.
