x3000 + wap200 in wireless repeater mode
d.gladkovsky
Bought wap200. I can't adjust the wireless repeater mode. Linksys x3000 supports wap200? What settings need to be made?
thanks for help
jonatrod
Level 7
Level 7
Good morning
Hi Dmitry, thanks for using our forum, my name is Johnnatan and I am part of the Small business Support community. The basic configuration that your devices needs in order to create a cluster  are:
1. Same SSID
2. Same password policies
3. DHCP just in the one of them
4. The Mac address of both devices
5. Same Channel
6. Then use the  roaming feature (WDS)
Also, I recommend you to post your question here , here you you can have more feedback on your case, more users will see it there because the X3000 is not a Cisco Small Business product, here they could help you with your device and they a re going to help you with your question about the AP. I hope you find this answer useful and I apologize for the issues you are having
*Please mark the question as Answered or rate it so other users can benefit from it"
Greetings,
Johnnatan Rodriguez Miranda.
Cisco Network Support Engineer.
“Please rate useful posts so other users can benefit from it” Greetings, Johnnatan Rodriguez Miranda. Cisco Network Support Engineer.
