Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful. Virtual Assistant- Discover support content and options for your gearSupport page index - Contains a ...
Hello all, I'm having a weird issue with a dozen WAP4410N we just bought : The MAC address assigned to them (i.e. the one printed on the products body) apparently changes for no reason (that I can understand anyway). I noticed this because I assigned...
I have 3 WAP321, all set to uk time zone, all the settings restor apart from the time on reboot that defaults back to 1999 despite NTP server listed, interestingly have to manually reset time to present before NTP will update it, wonder if this is pa...
I have 3 WAP321, all set to uk time zone, all the settings restore apart from the time, on reboot that defaults back to 1999 despite NTP server listed, interestingly have to manually reset time to present before NTP will update it, wonder if this ...
I want to setup my wap321 to not go to the Captive potal login page ,I want everyone to be authenticated automatically. I just want them to be redirected to my home page the first time they try and visit any page.I have the CP setup but I dont see a...
Hey there,I have a customer who has 2x AP541-K9 with the latest firmware installed. They are setup in a cluster and share one lan. The customer is experiencing problems with connecting and sudden drops of connectivity. The customers has given us feed...
Hello EveryoneRequesting you help will WAP4410n accept a HGA9N high gain antenna, I know the connector are different since the HGA9N has a N-type connector and the access point has R-SMA three connections, but wondering if purchasing a cable of about...
Hello all,I have 4x Cisco WAP4410N wifi access points. All of these are POE enabled devices and have been patched in and evenly distributed across our network maximizing the broadcast area of the point.The access points support several 'modes' of ope...
Hello, I have two WAP4410n and I want to use it in roaming mode. All two points configured to use same SSID, psk-key, but used different channels (5 and 9). The problem is that sometime second point is not accessible until I restart it. I connect to ...
Still having issues. I reconnected 4 laptops today on 2 different WAP4410n APs. The user will let me know if they get disconnected. Yesterday I even reflashed the firmward on them. Also in order to reconect to one of the Waps I had to cycle the power...
Hi,We are thinking of buying a WAP321 to use for captive portal.Is it possible to configure it so that multiple guests and use the same username and password simultaneously?If we have 10 guests in the office we don't want to configure 10 usernames fo...
I'm looking at a stack of WAP200 and WAP4410N APs. I'd like to use Cacti to track number of associations on each AP.What's the OID I should be querying?Are there multiple OIDs that would correspond to the multiple SSIDs? I'm running 2 SSIDs on all ...
Hello,I have two WAP4410N devices on my network.When I try to connect with a wireless device (iPad, Smartphone, etc...) it does not connect.However, if I assing that device a static IP, it connects.Here is the setup:2 WAP4410Ns that have static IP's...
After hours of testing and configuring I can say it’s not the same issue as discussed in the link above. I have the same problem as mentioned at the beginning.Our set-up: We have Mac, windows and mobile clients and Cisco networking equipment. We woul...
Hello All,Our company located on 2 floor of a bussiness buiding. I just bought 6 devices of Cisco WAP321 and would like to setup a wireless so users can move from 1 floor to the other floor with wireless still connect and the speed is at the fastest...
Hello dear support i have issues with my 3 Cisco WAP200, they are rebooting after uptime from 9 to 20 days, i've tried to use latest firmware available 2.0.4.0 but it makes no differance to 2.0.2.4. I can't see logs to point out the problem (by SNMP ...
