01#Aironet 1600 (AIR-CAP1602i) & 3850 WLC (WS-C3850-24T-L)
smsabetsm
Hi Friends
Trying to join 1602i (AIR-CAP1602i-E-k9) to 3850 (WS-C3850-24T) WLC but after join to WLC, the access point keeps rebooting
3850# Sho Version
Cisco IOS Software, IOS-XE Software, Catalyst L3 Switch Software (CAT3K_CAA-UNIV
ERSALK9-M), Version 03.03.03SE RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2014 by Cisco Systems, Inc.
Compiled Sun 27-Apr-14 18:33 by prod_rel_team
Cisco IOS-XE software, Copyright (c) 2005-2014 by cisco Systems, Inc.
All rights reserved.  Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0.  The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY.  You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0.
(http://www.gnu.org/licenses/gpl-2.0.html) For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
ROM: IOS-XE ROMMON
BOOTLDR: C3850 Boot Loader (C3850-HBOOT-M) Version 1.1, RELEASE SOFTWARE (P)
Ctrl1 uptime is 59 minutes
Uptime for this control processor is 1 hour, 1 minute
System returned to ROM by reload
System image file is "flash:packages.conf"
Last reload reason: reload
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
License Level: Ipbase
License Type: Permanent
Next reload license Level: Ipbase
cisco WS-C3850-24T (MIPS) processor with 4194304K bytes of physical memory.
Processor board ID FOC1729V00P
1 Virtual Ethernet interface
28 Gigabit Ethernet interfaces
4 Ten Gigabit Ethernet interfaces
2048K bytes of non-volatile configuration memory.
250456K bytes of Crash Files at crashinfo:.
1609272K bytes of Flash at flash:.
0K bytes of Dummy USB Flash at usbflash0:.
0K bytes of  at webui:.
Base Ethernet MAC Address          : d0:c7:89:74:ef:00
Motherboard Assembly Number        : 73-12238-06
Motherboard Serial Number          : FOC17283XTY
Model Revision Number              : B0
Motherboard Revision Number        : D0
Model Number                       : WS-C3850-24T
System Serial Number               : FOC1729V00P
Switch Ports Model              SW Version        SW Image              Mode
*    1 32    WS-C3850-24T       03.03.03SE        cat3k_caa-universalk9 INSTALL
Configuration register is 0x102
3850#show wireless mobility summary
Mobility Controller Summary:
Mobility Role                                   : Mobility Controller
Mobility Protocol Port                          : 16666
Mobility Group Name                             : default
Mobility Oracle IP Address                      : 0.0.0.0
DTLS Mode                                       : Enabled
Mobility Domain ID for 802.11r                  : 0xac34
Mobility Keepalive Interval                     : 10
Mobility Keepalive Count                        : 3
Mobility Control Message DSCP Value             : 48
Mobility Domain Member Count                    : 1
Link Status is Control Link Status : Data Link Status
Controllers configured in the Mobility Domain:
IP               Public IP        Group Name       Multicast IP     Link Status
192.168.188.22   -                default          0.0.0.0          UP   : UP
3850#show wireless country configured
 Configured Country.............................: AU  - Australia
 Configured Country Codes
        AU  - Australia : 802.11a Indoor,Outdoor/ 802.11b / 802.11g
1602i#show version
Cisco IOS Software, C1600 Software (AP1G2-K9W8-M), Version 15.2(4)JB5h, RELEASE
SOFTWARE (fc1)
Compiled Wed 16-Apr-14 00:32 by prod_rel_team
ROM: Bootstrap program is C1600 boot loader
BOOTLDR: C1600 Boot Loader (AP1G2-BOOT-M) LoaderVersion 15.2(2)JAX, RELEASE SOFT
WARE (fc1)
APc067.af86.55a3 uptime is 7 minutes
System image file is "flash:/ap1g2-k9w8-mx.152-4.JB5h/ap1g2-k9w8-mx.152-4.JB5h"
Last reload reason:
export@cisco.com.
cisco AIR-CAP1602I-E-K9 (PowerPC) processor (revision B0) with 229366K/32768K by
tes of memory.
Processor board ID FGL1739W06Y
PowerPC CPU at 533MHz, revision number 0x2151
Last reset from power-on
LWAPP image version 10.1.130.0
1 Gigabit Ethernet interface
2 802.11 Radios
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: C0:67:AF:86:55:A3
Part Number                          : 73-14671-04
PCA Assembly Number                  : 000-00000-00
PCA Revision Number                  :
PCB Serial Number                    : FOC17374QRS
Top Assembly Part Number             : 800-38552-01
Top Assembly Serial Number           : FGL1739W06Y
Top Revision Number                  : A0
Product/Model Number                 : AIR-CAP1602I-E-K9
Configuration register is 0xF
3850# Show logging
Ctrl1#
*Jun 14 05:37:44.747: *%CAPWAP-3-ALREADY_IN_JOIN: 1 wcm:  Dropping join request
from AP c025.5c96.90e0 - AP is already in joined state
*Jun 14 05:37:44.750: *%CAPWAP-3-DATA_TUNNEL_DELETE_ERR2: 1 wcm:  Failed to dele
te CAPWAP data tunnel with interface id: 0x0 from internal database. Reason: AVL
 database entry not found
*Jun 14 05:37:50.040: *%CAPWAP-3-ALREADY_IN_JOIN: 1 wcm:  Dropping join request
*Jun 14 05:37:50.042: *%CAPWAP-3-DATA_TUNNEL_DELETE_ERR2: 1 wcm:  Failed to dele
*Jun 14 05:38:05.467: *%CAPWAP-3-ALREADY_IN_JOIN: 1 wcm:  Dropping join request
*Jun 14 05:38:05.470: *%CAPWAP-3-DATA_TUNNEL_DELETE_ERR2: 1 wcm:  Failed to dele
*Jun 14 05:38:10.760: *%CAPWAP-3-ALREADY_IN_JOIN: 1 wcm:  Dropping join request
*Jun 14 05:38:10.762: *%CAPWAP-3-DATA_TUNNEL_DELETE_ERR2: 1 wcm:  Failed to dele
*Jun 14 05:38:26.672: *%CAPWAP-3-ALREADY_IN_JOIN: 1 wcm:  Dropping join request
*Jun 14 05:38:26.675: *%CAPWAP-3-DATA_TUNNEL_DELETE_ERR2: 1 wcm:  Failed to dele
*Jun 14 05:38:31.968: *%CAPWAP-3-ALREADY_IN_JOIN: 1 wcm:  Dropping join request
*Jun 14 05:38:31.970: *%CAPWAP-3-DATA_TUNNEL_DELETE_ERR2: 1 wcm:  Failed to dele
*Jun 14 05:38:47.388: *%CAPWAP-3-ALREADY_IN_JOIN: 1 wcm:  Dropping join request
*Jun 14 05:38:47.390: *%CAPWAP-3-DATA_TUNNEL_DELETE_ERR2: 1 wcm:  Failed to dele
*Jun 14 05:38:52.680: *%CAPWAP-3-ALREADY_IN_JOIN: 1 wcm:  Dropping join request
*Jun 14 05:38:52.682: *%CAPWAP-3-DATA_TUNNEL_DELETE_ERR2: 1 wcm:  Failed to dele
*Jun 14 05:39:08.100: *%CAPWAP-3-ALREADY_IN_JOIN: 1 wcm:  Dropping join request
*Jun 14 05:39:08.102: *%CAPWAP-3-DATA_TUNNEL_DELETE_ERR2: 1 wcm:  Failed to dele
*Jun 14 05:39:13.396: *%CAPWAP-3-ALREADY_IN_JOIN: 1 wcm:  Dropping join request
*Jun 14 05:39:13.398: *%CAPWAP-3-DATA_TUNNEL_DELETE_ERR2: 1 wcm:  Failed to dele
*Jun 14 05:39:29.024: *%CAPWAP-3-ALREADY_IN_JOIN: 1 wcm:  Dropping join request
*Jun 14 05:39:29.026: *%CAPWAP-3-DATA_TUNNEL_DELETE_ERR2: 1 wcm:  Failed to dele
*Jun 14 05:39:34.320: *%CAPWAP-3-ALREADY_IN_JOIN: 1 wcm:  Dropping join request
*Jun 14 05:39:34.322: *%CAPWAP-3-DATA_TUNNEL_DELETE_ERR2: 1 wcm:  Failed to dele
*Jun 14 05:39:46.377: *%DTLS-3-HANDSHAKE_FAILURE: 1 wcm:  Failed to complete DTL
S handshake with peer 192.168.188.25  for AP 0000.0000.0000Reason: sslv3 alert u
nexpected message
1602i# Show Logging
Translating "CISCO-CAPWAP-CONTROLLER"...domain server (255.255.255.255)
*Mar  1 00:01:01.591: %CAPWAP-3-ERRORLOG: Could Not resolve CISCO-CAPWAP-CONTROL
LER
*Mar  1 00:01:01.591: %LWAPP-3-CLIENTERRORLOG: LWAPP LED Init: incorrect led sta
te 255
*Mar  1 00:01:02.011: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to up
*Mar  1 00:01:02.247: %LINK-6-UPDOWN: Interface Dot11Radio1, changed state to up
*Mar  1 00:01:08.315: %SSH-5-ENABLED: SSH 2.0 has been enabledlwapp_crypto_init:
 MIC Present and Parsed Successfully
*Mar  1 00:01:09.075: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to r
eset
*Mar  1 00:01:09.075: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to r
eset
*Mar  1 00:01:18.755: Logging LWAPP message to 255.255.255.255.
*Mar  1 00:01:29.255: APAVC: Succeeded to activate all the STILE protocols.
*Mar  1 00:01:29.255: APAVC: Registering with CFT
APAVC: CFT registration of delete callback succeeded
APAVC: Reattaching  Original Buffer pool for system use
Pool-ReAtach: paks 9355 radio8747
*Mar  1 00:01:36.415: %CDP_PD-4-POWER_OK: Full power - INJECTOR_CONFIGURED_ON_SO
URCE inline power source
*Mar  1 00:01:37.487: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to up
*Mar  1 00:01:38.487: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio
*Mar  1 00:01:38.543: %LINK-6-UPDOWN: Interface Dot11Radio1, changed state to up
*Mar  1 00:01:39.206: %CAPWAP-3-ERRORLOG: Go join a capwap controller
*Jun 14 05:47:22.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_i
p: 192.168.188.22 peer_port: 5246
*Jun 14 05:47:22.335: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio
*Jun 14 05:47:24.287: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully
 peer_ip: 192.168.188.22 peer_port: 5246
*Jun 14 05:47:24.287: %CAPWAP-5-SENDJOIN: sending Join Request to 192.168.188.22
*Jun 14 05:47:29.287: %CAPWAP-5-SENDJOIN: sending Join Request to 192.168.188.22
*Jun 14 05:47:29.291: %DTLS-5-ALERT: Received WARNING : Close notify alert from
192.168.188.22
*Jun 14 05:47:29.291: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 192
.168.188.22:5246
*Jun 14 05:47:29.291: %CAPWAP-3-ERRORLOG: Go join a capwap controller
*Jun 14 05:47:22.291: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully
*Jun 14 05:47:22.291: %CAPWAP-5-SENDJOIN: sending Join Request to 192.168.188.22
*Jun 14 05:47:27.291: %CAPWAP-5-SENDJOIN: sending Join Request to 192.168.188.22
*Jun 14 05:47:27.295: %DTLS-5-ALERT: Received WARNING : Close notify alert from
192.168.188.22
*Jun 14 05:47:27.295: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 192
.168.188.22:5246
*Jun 14 05:47:27.347: %LWAPP-3-CLIENTERRORLOG: LWAPP LED Init: incorrect led sta
te 255
*Jun 14 05:47:27.375: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to a
dministratively down
*Jun 14 05:47:27.375: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to a
*Jun 14 05:47:27.379: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to up
*Jun 14 05:47:27.431: %LINK-6-UPDOWN: Interface Dot11Radio1, changed state to up
*Jun 14 05:47:28.379: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio
0, changed state to down
*Jun 14 05:47:28.423: %LINK-6-UPDOWN: Interface Dot11Radio1, changed state to do
wn
*Jun 14 05:47:28.431: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to r
eset
*Jun 14 05:47:29.415: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio
*Jun 14 05:47:29.423: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio
1, changed state to down
*Jun 14 05:47:29.467: %LINK-6-UPDOWN: Interface Dot11Radio1, changed state to up
*Jun 14 05:47:29.475: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to do
wn
*Jun 14 05:47:29.483: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to r
eset
*Jun 14 05:47:30.467: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio
*Jun 14 05:47:30.475: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio
*Jun 14 05:47:30.519: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to up
*Jun 14 05:47:31.519: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio
*Jun 14 05:47:37.431: %CAPWAP-3-ERRORLOG: Go join a capwap controller
*Jun 14 05:47:44.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_i
*Jun 14 05:47:44.287: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully
*Jun 14 05:47:44.287: %CAPWAP-5-SENDJOIN: sending Join Request to 192.168.188.22
*Jun 14 05:47:49.287: %CAPWAP-5-SENDJOIN: sending Join Request to 192.168.188.22
*Jun 14 05:47:49.291: %DTLS-5-ALERT: Received WARNING : Close notify alert from
192.168.188.22
*Jun 14 05:47:49.291: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 192
.168.188.22:5246
2 Accepted Solutions
Leo Laohoo
Not going to work.  If you want AP for Australia, you need a regulatory domain of "-Z".
8 Replies 8
Leo Laohoo
Hi Leo
For product AIR-CAP1602I-E-K9 what country have to configured?
flowed this table:
change country to turkry
3850# show wireless country configured
 Configured Country.............................: TR  - Turkey
        TR  - Turkey : 802.11a Indoor,Outdoor/ 802.11b / 802.11g
but ap Not going to work.crying
3850#
*Jun 14 12:14:16.492: *%CAPWAP-3-ALREADY_IN_JOIN: 1 wcm:  Dropping join request
*Jun 14 12:14:16.496: *%CAPWAP-3-DATA_TUNNEL_DELETE_ERR2: 1 wcm:  Failed to dele
*Jun 14 12:14:31.916: *%CAPWAP-3-ALREADY_IN_JOIN: 1 wcm:  Dropping join request
*Jun 14 12:14:31.918: *%CAPWAP-3-DATA_TUNNEL_DELETE_ERR2: 1 wcm:  Failed to dele
*Jun 14 12:14:37.210: *%CAPWAP-3-DATA_TUNNEL_DELETE_ERR2: 1 wcm:  Failed to dele
*Jun 14 12:14:52.628: *%CAPWAP-3-ALREADY_IN_JOIN: 1 wcm:  Dropping join request
*Jun 14 12:14:52.630: *%CAPWAP-3-DATA_TUNNEL_DELETE_ERR2: 1 wcm:  Failed to dele
*Jun 14 12:14:57.920: *%CAPWAP-3-ALREADY_IN_JOIN: 1 wcm:  Dropping join request
*Jun 14 12:14:57.922: *%CAPWAP-3-DATA_TUNNEL_DELETE_ERR2: 1 wcm:  Failed to dele
*Jun 14 12:15:13.340: *%CAPWAP-3-ALREADY_IN_JOIN: 1 wcm:  Dropping join request
*Jun 14 12:15:13.342: *%CAPWAP-3-DATA_TUNNEL_DELETE_ERR2: 1 wcm:  Failed to dele
*Jun 14 12:15:18.632: *%CAPWAP-3-ALREADY_IN_JOIN: 1 wcm:  Dropping join request
*Jun 14 12:15:18.634: *%CAPWAP-3-DATA_TUNNEL_DELETE_ERR2: 1 wcm:  Failed to dele
On the WLC, use the AP authorization list based on their MAC address. The AP authorization list is available under Security > AP Policies in the WLC GUI.
Also paste the output of this command:
show ap auth-list
​Regards
Dont forget to rate helpful posts
Hi Sandeep
I cant find in WLC GUI AP authorization list !?
I see in WLC GUI:
Security > AAA > AP Policy > Policy Configuration :
Authorize MIC APs against AAA (Check box)
AP with Manufacturing Installed Certificate (Check box)
3850#show ap auth-list
Authorize MIC APs against AAA                 : Disabled
Authorize LSC APs against Auth-List           : Enabled
APs Allowed to Join:
  AP with Manufacturing Installed Certificate : Disabled
  AP with Self-Signed Certificate             : Enabled
  AP with Locally Significant Certificate     : Disabled
AP1602i# (error log)
*Mar  1 00:02:28.874: %CAPWAP-3-ERRORLOG: Go join a capwap controller
*Mar  1 00:02:28.874: %CAPWAP-3-ERRORLOG: ApMgr list is empty..
*Mar  1 00:02:28.874: %CAPWAP-3-ERRORLOG: No valid AP manager found for controll
er 'Ctrl1' (ip: 192.168.188.22).
*Mar  1 00:02:28.874: %CAPWAP-3-ERRORLOG: Failed to join controller Ctrl1.
*Mar  1 00:02:28.874: %CAPWAP-3-ERRORLOG: Failed to join controller.
*Mar  1 00:02:28.874: %CAPWAP-3-ERRORLOG: SM handler: Failed to process timer me
ssage. Event 31, state 2
*Mar  1 00:02:28.874: %CAPWAP-3-ERRORLOG: Failed to handle timer message.
*Mar  1 00:02:28.874: %CAPWAP-3-ERRORLOG: Failed to process timer message.
Not in Bound state.
*Mar  1 00:02:18.646: %CAPWAP-3-ERRORLOG: No valid AP manager found for controll
*Mar  1 00:02:18.646: %CAPWAP-3-ERRORLOG: Failed to join controller Ctrl1.
*Mar  1 00:02:18.646: %CAPWAP-3-ERRORLOG: Failed to join controller.
*Mar  1 00:02:18.646: %CAPWAP-3-ERRORLOG: SM handler: Failed to process timer me
*Mar  1 00:02:18.646: %CAPWAP-3-ERRORLOG: Failed to handle timer message.
*Mar  1 00:02:18.646: %CAPWAP-3-ERRORLOG: Failed to process timer message.
*Mar  1 00:02:18.646: %CAPWAP-3-ERRORLOG: Go join a capwap controller
*Mar  1 00:02:28.650: %CAPWAP-3-ERRORLOG: Go join a capwap controller
*Mar  1 00:02:28.650: %CAPWAP-3-ERRORLOG: ApMgr list is empty..
*Mar  1 00:02:28.650: %CAPWAP-3-ERRORLOG: No valid AP manager found for controll
*Mar  1 00:02:28.650: %CAPWAP-3-ERRORLOG: Failed to join controller Ctrl1.
*Mar  1 00:02:28.650: %CAPWAP-3-ERRORLOG: Failed to join controller.
*Mar  1 00:02:28.650: %CAPWAP-3-ERRORLOG: SM handler: Failed to process timer me
*Mar  1 00:02:28.650: %CAPWAP-3-ERRORLOG: Failed to handle timer message.
*Mar  1 00:02:28.650: %CAPWAP-3-ERRORLOG: Failed to process timer message.
Not in Bound state.
AP with Manufacturing Installed Certificate (Check box) - Enable it.
Please enable AP with Manufacturing Installed Certificate and then wait for 2-3 minutes. AP will join.
thanks a lot dear Sandeep wink
