1020 booting loop.....Help
dazzo
Community Member
I have upgraded my controller to 4.2.130, and then I attempted to give one of my AP's a static IP address, and since then its in a booting loop.
I partially registers with the controller, and then reboots itself, and I cant ping it or reset the config.
What options do I have?
David
Scott Fella
What does the log show. You can see a join, but what error do you see after that. make sure the time is set correctly on the wlc, verify that there is not any ap authorization configured that may be blocking the ap from joining. Here is a doc you can go over to make sure you are setting up the network and wlc correctly:
http://www.cisco.com/en/US/docs/wireless/access_point/1000/quick/guide/ap1000qs.html#wp34036
-Scott
Thanks for your advice.
I managed to work out using the debug commands that the static IP was using a different subnet mask to the AP-Manager
Cheers
